replacement battery
bk5r
38
59
Congress, AZ
anybody know the diff between gyz20h and gyz20h-a
need new battery
any better replacement battery
thanks in advance
Bob K
HondaTech
Here's the 2 batteries specs, I dont see any difference.
Screenshot 20230506 131443 Chrome
Screenshot 20230506 131423 Chrome
115,290
need new battery
Use the search up top for this. Topic has been discussed at nausea. Also, what yr miles Talon? You need one already?
Come back tell us what you ended up with. Dont leave us hanging like Epstine
bk5r
38
59
Congress, AZ
First thing I did. Found nothing relevant to replacing original, just second battery.
At another talon website found an interstate CYTX20H-BS priced between the yuasa H or H-A
I'll try calling YUASA monday and find out the difference.
I have just under 6k on a 2019.
I think the AZ heat may be a factor.
Will go back to storing the battery in a cooler for the summer and hope that gives a longer life.
HondaTech
Both the GYZ and YTX batteries are AGM, thr main difference being GYZ are factory activated when delivered and YTX are filled/activated by the seller (or atleast should be) when you purchase it.
Honda switch to GYZ for the 2012 model year Goldwing, they also use GYZ in their Automatic ATVs and YTX in the manual/electric shift models.
From Yuasa's website:
Screenshot 20230506 181938 Chrome
Screenshot 20230506 181923 Chrome
115,290
Add a trickle charger, thats what I have in my P1 and Talon. Not sure what your accessories are? But if u dont have a second battery for just them, Id suggest that.
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
AZ heat definitely shortens lead acid type lifespan. I'm a bit amazed a lithium battery over 10 years old is still going strong in one of my bikes. I'm going lithium when my Talon needs the battery replaced.
bk5r
38
59
Congress, AZ
ok called yuasa for clarification.
same battery but different terminals.
rechecked the photos and sure enough that's it
rep said talon definitely needs the H-A because it allows for flush mounting the cables.
hard to justify the cost of lithium but will give it a thought.
Thanks for all the input.
Bob K
115,290
Bob K
still get u a trickle charger and plug it in when not in use. You will thank yourself and your battery will to! The set up is cheaper than a new battery. Check it out in my build post #218
