P1000 Replacing clutch pack on the Beast
322,676
Thanks,CP I haven't seen or read anything about oil light problems on the forum but it will try to move when you first start it and the oil is cold it is a first that I have heard of I thought about checking the filter but I would have to drain the oil and if I take it to the dealer they will have to drain it again That is a pricey check HaHa
Paul
I wouldnt think just filter because if you garnade a set of clutches the friction material isn't enough to set off the light so I wouldn't think just normal debris would either. How many volts you at any idea?
pct
pct
Lost in the hills
790
1,023
Letart WV
I have a fully charged battery any special spot to check never found any blown fuses
322,676
I don't think it's voltage related but was curious if it's starting fine and not using heavy juice during it's probably non issue. Low power will do that though. I agree you need to go in. The light is different
Reactions: Eltobgi
pct
pct
Lost in the hills
790
1,023
Letart WV
What I was wandering if the clutch pack had enough play to not let pressure build up or a seal blown I think it might be time to put the ole girl on the trailer to the dealer but they might not want to cover it due to water in the air filter
Reactions: Eltobgi
popeye
popeye
3,275
14,644
kapowsin, Wa
Maybe check all electrical conections back at the transmission/clutch area. Maybe you got a little water in them too. Water in the oil pressure sensor?
jocojonson
jocojonson
27
27
midland mi
Yes I do have a dual battery system! All accessories are seperate from factory electrical! Why what were you thinking?o_O
Just wondering if clutch problems voltage issues I'M just finishing my dual battery set up
Reactions: Eltobgi
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
I would troubleshoot the oil pressure sensor. Probably an ohm check in the manual. Should be able to trace the wires to the ECM from the manual and check it there. If your oil light is coming on, I don't believe it will lock the clutch unless you do the bypass, maybe...
pct
pct
Lost in the hills
790
1,023
Letart WV
I got the clutch reset to work and everything on the dash was working it had reverse and forward backed it down the driveway and put it in low took off normally shifted in to 2nd ok pulled in the shop turned it off getting ready to take a test ride around the yard and it wouldn't move forward or reverse but if it is motor is cold it will move
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Order your clutch pack and oil change and you will be happy! She returns to the Beast you once knew! Job is really not that bad! Lot of good info provided by @CumminsPusher! We will be here for any questions!
Jshell3
Dang. Do you think Honda would help? Warranty or not, I thought they kinda paid special attn to clutch issues.
Reactions: pct
Eltobgi
Eltobgi
4,599
15,186
North Dakota
No guarantees! But I don't see any reason they wouldn't! Call your dealer and let us know what they say! Good luck bud!
pct
pct
Lost in the hills
790
1,023
Letart WV
Are there any vendors here on the forum that sell parts I would like buy my parts from them if I could
pct
pct
Lost in the hills
790
1,023
Letart WV
wonder if they were warrenty replacements
pct
pct
Lost in the hills
790
1,023
Letart WV
Most dealers up here have to order and are 2 weeks out
