P1000 Replacing clutch pack on the Beast
208,730
I also felt bad! For the record I would recommend seeing a doctor @Smitty335 for the nosebleeds! Just trying to get a laugh out of him with what my wife calls my "Inappropriate Sense of Humor":confused:
You know, I hear that a lot (Inappropriate since of humor) couldn't be me, I just hanging out with the wrong crowd. HA!
Ridem32
Ridem32
938
848
Terry
Has anyone that has had to replace clutch what was your clutch initial clearance? The clearance should be 0.028-0.035 in. If it's out of specs they make end plates marked 1 thru 11 from 2.4mm thickness to 3.5mm. Just a thought for clutches that keep going out.
69,609
This is off topic, have any of you been in a fender bender that 6 air bags went of, well I did 1/2/17 and since I have several nose bleeds? I usually have nose bleeds maybe 1 in 5 years. When the bags went off, there was a terrible odor.
the bags are charged by gunpowder I believe. alot of people get burns from it. Probably inhaled a bunch.
208,730
Yea on one hand. wonder what happens in a car fire that the air bag din't go off with the gun powder??
322,676
When you buy a set they come preloaded and set in the basket.
208,730
They show them in the manual but I haven't saw them for sale.
When you buy a manual, should we be getting the up dates for the manual from Honda? When I bought my manual, it had some lose leaf up dates. And I haven't got any up dates since then.
Reactions: pct
Ridem32
Ridem32
938
848
Terry
When you buy the clutch set it comes with fiber clutch plates & the steel plates & the end plate as a unit? Seems like you would still have to measure due to baskets being machined different.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Mine was preassembled! Just soaked it in HN4 overnight! No measuring!
322,676
It's a matched set.
Reactions: pct and sharp
pct
pct
Lost in the hills
790
1,023
Letart WV
Hey,EItobgi jut saw this I'm having about the same problem you are did your oil light come on when your pioneer quit pulling mine comes on while trying to do a reset on the clutch and cant get it to reset oil is clean no smell haven't checked clutches yet but it is looking like that might be the problem but I haven't heard anyone mention oil light coming on when the clutch packs go south
Paul
Reactions: CumminsPusher
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Paul
I honestly cant remember, but if i had to guess i would say NO that they oil light did not come on! Sorry to hear you are having problems! I am wondering if yours is an oil pressure issue possibly attributable to a clogged internal screen? The best advice i could give would be to let them cover it under warranty so everything is documented and continues to be covered! Let me know how it goes!
Reactions: pct
jocojonson
jocojonson
27
27
midland mi
Do you have duel batteries ?
322,676
Thanks for the info
Paul
Mine didn't come on either. I'm thinking there is a problem with oil pressure in yours like Eltogbi mentioned I've never heard someone say oil light same time.
Reactions: Eltobgi and pct
pct
pct
Lost in the hills
790
1,023
Letart WV
Thanks,CP I haven't seen or read anything about oil light problems on the forum but it will try to move when you first start it and the oil is cold it is a first that I have heard of I thought about checking the filter but I would have to drain the oil and if I take it to the dealer they will have to drain it again That is a pricey check HaHa
Paul
pct
pct
Lost in the hills
790
1,023
Letart WV
This all started over an E fault if that helps
