ok guys wanted reverse lights on 3 way switch on off on. All the way up is basic hot to the rear lights. Then off middle. Then down/on while headlights are on and shifted into reverse rear lights come on. So I wired relay to this #85 headlight trigger #86 reverse trigger. #30 fused power. And last #87 power out. All worked great till machine wouldn’t start. I’m thinking my reverse switch being a ground switch is messing with it. Possibly backfeeding. Because gear indicator is confused. Can I get a diode and plum that in between relay and reverse trigger? Or is there a way to wire it correctly? Thanks in advance
