Just want to see if I'm on the right track with this. I want to install a pair of white reverse lights, I've looked through the Key On Power sticky thread in the mod forum, but just want a little reassurance. Once I mount the two lights, I would then either combine the red wires from the lights, or run each one individually, and tap them into the two plugged black wires as shown in the sticky thread, and then ground each light, and that should give me white lights when the machine is in reverse, correct?
