P500 ripsaws on order
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
These tires are a freaking bear i gave up for the night trying to set the bead the side walls are so stiff i cant get them to flex enough to get the air to stay in there ugh :mad:
Have you tried wrapping a ratchet strap around them?
I usually have to do that to E load range truck tires.
Reactions: p500fan
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
Yep Ratchet Strap, soap water on the bead, high pressure air, wiggle the rim and watch the fingers!
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
IF that does not work a little starter fluid and blow it on the rim!
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
Strap wasnt working so i went full redneck and ol startin fluid and a tourch lol shes on there lol yutt
Reactions: joeymt33
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
Comparison and with 10psi the measure 25 1/4
20150730 202217
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
Quick 3 sprays at differents sides and quick hit with the tourch and boom shes on lol btw anyone reading this if you attempt remove valve stem core and use very little fluid dont need much but im not recommending this method i still have burn scars from exploding tires
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
I was mounting 35s once and couldnt get it set so being as impatient as i am i used like an entire can and the tire literally exploded i had crazy burns on my neck chest and shoulder it wasnt good but i was laughing so hard
p500fan
p500fan
417
354
Sand Point, AK
What psi are your running
I'm running 10psi. No "bulge" at the bottom, but the tread is not "ballooned". They were shipped mounted on my 14" rims, and that was the psi they all were at. Didn't see any reason to change.
