P1000m5 Rock Donkey v2 Long Travel
Thought maybe @JTW rubbed off on you a little too much :eek:
I gave @JTW enough crap God decided to shut me up.
I really think the 2nd factory was a consequence of the first because I finished a red trail and kept riding red trails the rest of the day with 3wd after the first one blew.
The first all balls really should not have failed unless it was a defect. It was a LE kinda day.
cough cough bulls*** cough cough
6E00E5E8 8B32 4BCC BAE3 6E46CB72DD15
Someone posted this earlier.
75FCB60B 796F 458B BB9C D2919AD8C746
70,225
I'll never harp on another brand or rider. Were all on borrowed time!
I will especially @JTW . 3 axles in a couple hundred yards has to be a record.
It’s fun to give each other crap and I don’t take it personally. If I’m NOT giving you crap it mean I REALLY don’t like you.
Scary I was wondering if something was out of line.
I really don’t think so I think the 2nd factory was weakened by the first two failures and the extra abuse it got from taking rough trails in 3wd.
Its not a cheap failure, but I’m glad it failed where it did, doing nothing, in a spot that took turf mode to get out of. The rest of the day would have been a miserable time for it to fail with the trails we took and it WOULD have failed on any of them if it failed where it failed, slowly backing up, with the wheels straight.
I wasn’t going to do anything before Takeover but...
I decided to swap out my winch ropes since they were getting frayed again, ESPECIALLY the rear one, which after I was reminded how much trouble it is to swap the front I will be using the rear a LOT more.
13E14AB3 4E40 4F16 9715 6602034401A0
86627CBF E22B 44F0 8E3C 9B49542E7C87
8DBA3926 9C84 4A6C 9244 AB8B44F91F3D
I also wanted to put the factory exhaust back on because it’s so loud for my daughter when the full cab is on. I like the HMF sound but I like the quiet more, it doesn’t add any power and I’d only installed the HMF for the rear winch. In my search I ended up ordering a rear winch bumper/mount from @knuckledeep and decided that since I was going to rewire my backup lights to use some Rough Country Flush mount pods...Yes I have 95% of the tools and I could’ve made one but it wouldn’t have looked as nice and I am all for supporting a member who does good work.
9C742462 DE84 4403 9234 8D53F46E525A
(Not mine but work in progress of another one from him)
I decided I might as well move the existing rock lights I was using for backup lights to the bed area to light my HomeDepot Ridgid box stacks better at night.
66EB090D 0335 435B B3AE 34B8B05FFA35
11D8CE15 2E1E 4950 AB7C 729006AAE8B9
9571D29B 1E90 4074 92B7 34121128C81C
It’s light outside now but it’s MUCH better coverage especially for the stacks since they open to each side and the lights hit the bed from each side.
Then I decided that the rock light I’m using for a front dome would be better in a different place, that required me to move my HAM radio, which required me to move my wetsounds, which required me to move my tablet and my phone, which made me rewire everything above the dash, so decided if I was going to rewire and remount I might as well make it to where I can remove the roof and swap out for an alien shade...
While I was at it I removed the Chinese USB power converters because they were electrical trash and put all kinds of noise into the wetsounds, added 2-way SAE connectors and bought (3) Battery Tender SAE to USB plugs. I will power the VIRBs and my phone/tablet with them.
8F6FA8EB A81A 4DA4 9E5F E6A23E121A7C
A spare weldable clamp (still have to sandblast and powdercoat), scrap flatbar, some argon, Half a roll of solder, a roll of heat shrink, 2 rolls of tape, a pack of zip ties and MANY hours later I remembered why I had put it off so far....and why I’m going with Switch Pro setup on my next SxS.
A lot of work with little to really show for it except calmer OCD, and better lighting in the back area and cab.
E2D83293 EFE5 41C5 A146 18F87C93D19D
All wired and except for powdercoat on the radio mount, the extra flatbar to the back is for something I may do later.
I’m going to ride this weekend then clean it up, and swap the exhaust, adjust the valves, change the oil/filters, adjust the steering rack and replace the plastic bushings in it, since there’s starting to be some slack. I had contemplated just buying a new rack assembly since they are “only” $224 but @joeymt33 did a spectacular write up in this thread here. So I’m going to try adjusting first and if that and $10 in bushings doesn’t work I’ll replace it AFTER take over.
Similar threads
