P1000m5 Rock Donkey v2 Long Travel
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
Amazon has a new one for 240
I like the XE because it can be powered and still be waterproof
Yea, I wished they had just improved on this model rather than changing the housing when they changed models.
I am sure the 360 cameras will be great but for now I can’t get used to it
Reactions: ohanacreek
I wanted a VIRB 360 but DANG at the price.
A2679543 8F03 47D3 AB88 2407F810CD74 During cleanup from riding yesterday I noticed the SuperATV a-arms JUST rub the inner beadlock at full lock. I took a grinder to the under rim and cleaned the sharp edge off. Then hit the SATV arm and took about 3/16 of an inch off that corner and now there’s plenty of clearance at full lock.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
View attachment 63211 During cleanup from riding yesterday I noticed the SuperATV a-arms JUST rub the inner beadlock at full lock. I took a grinder to the under rim and cleaned the sharp edge off. Then hit the SATV arm and took about 3/16 of an inch off that corner and now there’s plenty of clearance at full lock.
Good catch! I bet that would be razor sharp after rubbing for a hundred miles.
Reactions: pct and ohanacreek
Had the clutch update done Friday.
Did some work around the house and up at our gate this afternoon and took my trails to save the driveway since it’s been raining so much around here.
It definitely engages differently vs before the update. It’s smoother on takeoff and shifting but when it’s not fully warmed up it will grab and let loose it never did that before. Not a shudder it grabs then lets go althogether.
I had a long todo list to get done but I’m going to try to reinitialize the clutch.
Side note with the rear floorboard plastic re-installed the exhaust volume is probably 50% less in the cab.
Reactions: Plumber32 and pct
Had a few mins to mess around today.
Got the first speed run in since I put the Blackwaters on. On the dash I could only get 61mph out of her but the Drive60 GPS I have for trail maps and my VIRB XE(card messed up and wouldn’t record) not said 68mph which is about right considering the stock tires were 25.25” at 12psi and the Blackwaters are 28.5” at 8psi.(measured on the machine)
1:1.128 ratio change.
That’s with a full windshield on. I’m wondering what it’s going to be in the spring with no windshield.
I like it, it’s not as wound up at 55 GPS speed / 48 on dash.
70,265
First time I ran 30s I was reading 58 and 67 gps. With more to go. It was scary at that speed. Now I've got power commander and exhaust it may just hit 70.
Reactions: chadbo
Oh its plenty but wasn’t scary... on of the tires is bad out of balance but I don’t really care how often am I at any kind of speed for more than a mile, I may take them to a tire shop and have them balanced.
70,265
I was on an old railroad bed ! But 60 is more than plenty
lee
lee
Village Idiot
2,443
13,833
Springfield Ohio
I don't like the glass beads for balance (or the home remedy bb's or snake oil eggs).
Have not tried it yet but something like this goes in my truck next time the mud tires need balanced.
Rubber granules stick to the insides of the tire but shake lose and redistribute if there is any vibration.
Internal Tire Balancing Product - Equal Flexx | IMI Products
If I ever get spunky and decide taking a beadlock loose is a good idea I may try that.
If I were keeping my truck I’d get some and put in my tires.
nbomar
nbomar
4,416
17,855
Springdale, AR
I’m using centramatics on my dually. The original expense is high, but I just leave them on there and never rebalance again.
I’m gonna pick up a used 350/3500 in the next year, I remember I’ll be talking to you about that.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
I had a jacked up Chevy with 35" tires. Went to Wal-Mart and bought 4 jars of the plastic air soft pellets. Dumped one in each tire and it worked fantastic!
212,458
How big a whole did you have to cut?
283,087
You got any more Rock Donkey Racing T shirts? Proper homage to your build title.
RD Shirt front
I was thinking about that the other day.
I never knew about that until you posted it originally. I tried to get in touch with them but no answer if @Hondasxs can help me out I’ll make a couple I like the Rat Fink styling going on there.
Similar threads
