P1000m5 Rock Donkey v2 Long Travel
Fudamentaly it doesn’t work. Your spring is compressed X amount to support Y load. After you add a lift kit the spring will still be compressed X amount but now you have moved the range the knuckle travels in.
More stress on the drive line and no change in spring rate.
(X and Y is engineer speak for stuff you wouldn’t understand if need to ask)
I guess it’s a mute point since Strongmade doesn’t work with SATV arms.
Yes the spring will be compressed X to support Y but with the preload off and the secondary (lighter) spring not as compressed with pre-load to bring the ride height up (bringing the ride height up with static geometry instead of pre-load force on the springs) there will be more travel in the shock and the lighter of the two springs can actually function....right?
Or am I just plain misunderstanding this if I am disregard.
I also get what you are doing. @nbomar wanted to avoid a lift but in the end had the preload turned up so high that it made more sense to go with lift and let the shocks work better.
But I don’t know how much preload you are at now
That’s my goal, but maybe I’m just misunderstanding suspension mechanics.
Well I found 3 pair of these at Tractor supply for $36 so I decided I would try them. They will fit a 28.5” tire I’m not sure thy have the length to go around a true 30” tire.
Dcb01deade0219160a3879651c0521dc
lee
lee
Village Idiot
2,332
13,077
Springfield Ohio
Is this where I say "Well bless your heart"?
Each wheel will support the same load.
(ok technically as you get further from the center of the earth the effect of gravity dose go down but you didn't say you wanted to clear 5 gallon buckets and pose on liebook).
So to support that same load the spring will compress the same amount.
You can change the amount of pre-load on the spring to archive a given ride bight.
But the total spring compression will be the same and therefore the effective spring rate (or the wheel rate).
So there will be no improvement in ride comfort.
I wasn’t sure how taking pre-load out was going to affect it so it was either going to achieve the same affect as preload and be a waste of time and money or it was going to work. Thanks for clearing it up, even if it was the opposite of what I wanted to hear.
Reactions: Cuoutdoors
208,013
Or make it worse! Springs are designed to support a certain weight, not ground clearance. The preload adjustment is to set spring sag, that is, jack your machine up until the shocks a fully extended, tires still on the ground, measure ground clearance, ride a little, measure ground clearance with passengers, beer, tools in the ride,that you usually haul, that will be your spring sag. If my ride has compression adjustments a spring sag of 2 to 3 inches is a good place to start, Adjust spring tension until you get 2 to 3 inches of spring sag, then start messing with the compression adjustments, if you are bottoming out, stiffen your compression and if you never bottom out back it down until you do on the hardest hits. If you stiffen your compression to the max and still bottoms out all the time, it's time to start all over, stiffen the preload on your springs and start over with compression adjustments. And the reverse works, may have to go back to the spring adjustment and let some tension off, if you have compression completely backed down and no bottoming. You want to bottom out occasionally. Kinda like having a long pecker and using half of it!
my99svt
my99svt
I identify as a lesbian
1,267
5,248
Broken Arrow, Oklahoma
Fox QS3 only have pre-load, and 3 settings. (I have dual springs so I have the ability to adjust spring crossover)
I have them set to stock ride height with stock tires. There’s just more weight than bone stock.
Works pretty good on softest for most riding and technical trails, mid for faster rough trails, and hardest if I feel like getting some airtime.
I’d NEVER get the stage 5 Elkas adjusted.
865e4da187c7b68bc68b3891f22b45e8
BigOL3
BigOL3
2,994
8,918
I found "spots" (holes/openings) in the under-frame I could place the hooks in and ratchet it down. Works great, pull the rear ones forward, and the front ones backwards.
208,013
It just takes a little time, I haven't had much time to mess with mine. And haven't put very many trail miles on yet. After Mulberry went two clicks stiffer on the high and two clicks softer on the slow speed compression, think I'm getting close! And it's going to be sweet!
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
@lee This is where I say bless my heart ... so are you saying that preload adjustment does not affect ride comfort?
I may be understanding that the weight of the ride will sag the spring the same amount no matter the preload ... but preload will change the shock travel which will change ride comfort correct? Then you have the whole soft, Med , firm settings.
I probably won’t understand the entire response but I want to so I may have to settle for discussing over beer at Takeover.
Reactions: ohanacreek
I’ve got shackles on the front bumper and welded a d-ring to the trailer frame just behind the hitch, and I tie to the ROPS on the back down to d-rings I welded at the rear corners of the trailer. People praise these things so I figured I’d spend $35 ($50 with the required Grade8 5/16” bolts) and try them out since I needed some new straps anyway.
It is much quicker to tie down and I don’t have the long straps that always end up loose in the wind no matter how well I tie them to themselves.
Reactions: BigOL3 and JTW
Similar threads
