P1000 Rotopax installed
Hondoman
Hondoman
727
1,697
Texas
Since my original thread got locked, I started this new one. Shown below is a 2 gallon mounted to the rear grab bar. The can and threaded stud/handle must be removed to raise the right rear seat but the rest of the mount can stay attached.
20190126 153436
20190126 153539
TheHoover
TheHoover
221
694
PNW
hondasxs.com
Reactions: Hondoman and BWAF
dnjones161
dnjones161
583
1,713
Ohio
I really like that location! I rarely ever pop the rear seats- especially on trips that I'd take extra fuel.
Did the mounting hardware come with the mount? If not what did you use to go through the grab bar?
Hondoman
Hondoman
727
1,697
Texas
Will the seats still flip up in that location?
Left seat is unaffected. Can and "locking" lever have to be removed to raise right seat.
Reactions: TheHoover
Hondoman
Hondoman
727
1,697
Texas
Mount only came with a backing plate and two short bolts 5/16 x 3/4" maybe, I used none of that.
I drilled through the grab bar and used stainless 5/16" x 1.5" bolts with lock and flat washers.
Reactions: dnjones161
dnjones161
dnjones161
583
1,713
Ohio
Looks to me like he bolted it thru
I don't know I suspect a fresh Gorilla Glue might be the way to go
@Hondoman Thank you, this is exactly what I was asking.
@JTW I'd go on about you annoying millennials but I think that has already been covered in another thread :p
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Lmao... I’m just too hot for them to handle!
Yes JTW is an annoying millenial.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I wonder if guys that have the harness bar could mount a rotopak to it.....
Reactions: JTW
Ragnar406
Ragnar406
The Great Bald One
4,450
17,034
Bella Vista, AR
If you have a mid panel that will usually cover the harness bar as well
Reactions: JTW
