Running bad. Baffle diagnosis?
GPR1500SC
GPR1500SC
861
2,426
North East MO
  2. Talon X LV
Cam went out. He said the intake lobe was almost completely flat. They have been doing alot of these going all the way back to the wheelers and Big Red. They say only machines that do a lot of cold starts. In other words 95% of my use. So if you're using it around the farm expect to buy an $800 cam soon. My 2014 went out at 685 miles this week. No help from Honda. And to think that buying a Honda was reason enough to not need an extended warranty. My Honda pride took a real shot to the nuts this week.
Sent from my XT1254 using Tapatalk
I here ya on the Honda pride.
The only Honda 700 in my circle is owned by a previous Polaris owner and bought a Honda because of there track record of making reliable products, well it ate two cams already and the only reason he still has it is because of his good treatment from the dealer.
He said if it goes into the shop one more time it is GONE!
Reactions: JTW and Farmer
swsebek
swsebek
2,854
5,835
pa
Well before I lose my Honda pride I'm going to have to here of a lot more of this problem happening. Cams do go bad....But most of the time it's due to something else or lack of proper lubricant at break in.I wouldn't exspect this at 685 miles or 3 years old.Im sorry you had this Issue Farmer. But I'm not buying the cold start BS they gave you.
Reactions: JTW and Tflynn
swsebek
swsebek
2,854
5,835
pa
Not immediately, probably on the 3rd oil change.
I meant the thread starter........No you Mr.Flynn broke in the Honda engine correctly
Reactions: Tflynn
Farmer
Farmer
2,973
17,161
Southern MO
Break in was according to manual. I'm picky about that stuff.
Reactions: swsebek
Farmer
Farmer
2,973
17,161
Southern MO
Just got back from fishing. Here's some pics... D6423c254b359c8e3f785daabc88cad598f6cda86c948ca607e4479c6423fed5E720fd6f99030cf4c871d7525bddece4
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
Damn I hate to see that. Looking at it, I just wonder is the cam the problem? Or the result of another problem like lack of lubrication?
Reactions: JTW and swsebek
Farmer
Farmer
2,973
17,161
Southern MO
No one was very clear exactly. I guess the two things they said are related. Short runs/starts,stops and lubrication. It could be bad hardening process on those particular cams. They said it has a hardened surface and once that's gone the lobes go quick. Who knows? Until Honda owns up to it, it's only speculation.
For now I'm gonna stick with it, drive it the same, and hope the new part number solves the problem.
I'm going back through the break in procedure and then I'll switch over to synthetic.
Reactions: Tflynn and swsebek
Farmer
Farmer
2,973
17,161
Southern MO
What year is it?
Crow_Hunter
Crow_Hunter
750
836
Riding a Canned Ham.
I read about that back when I first got my Honda Rincon back in 2007'ish.
At the time I think it was related to how the oil was delivered to the cam and having something to do with a chain or a oil passage and the orientation of the machine, maybe? I don't remember for sure. I thought they had fixed it though. Even then, I didn't think it was a terribly common problem though, from what I remember.
Might want to do some searching around on Rincon forums and see if there is a fix or a work around there since it is the same design.
Sorry for your problems. :(
Reactions: Farmer
Farmer
Farmer
2,973
17,161
Southern MO
2007? You'd think they would have figured it out by 2014. Right?
Reactions: elkguide
GPR1500SC
GPR1500SC
861
2,426
North East MO
  2. Talon X LV
What year is it?
It is a 2015
I had my times mixed up the first cam started giving trouble in about month 11 Honda fixed it under warranty the next one crapped out in 5 more months so it was out of the one year warranty and Honda took his top end and gave him a new one for free, but he had to pay labor.
Ross Power Sports where he bought it new installed it for free.
Reactions: elkguide
E
elkguide
3,377
7,964
Vermont
It is a 2015
A good dealer is worth a lot!
Most of the new oils are not great today so I switch every engine I own (except small tools) to synthetic soon after break in.
GPR1500SC
GPR1500SC
861
2,426
North East MO
  2. Talon X LV
+1 for the dealer
But down time is down time
Reactions: Farmer
tundraman
tundraman
141
175
I have 350 hours and 2000 miles on mine. The first winter I had it the oil level was rising. Took it the dealer to see if fuel was leaking by and they said no. Changed the oil, 4.5 quarts came out. Did some research and figure all the cold starts in the winter was causing condensation to get in the oil. I only use synthetic oil and change more often in winter. I also run it on the trails in the winter to burn the condensation out of it now. No problems with it and gets started up to a dozen times a day as I use it on the farm. So if you live in a cold climate, make a lot of short trips in winter, use synthetic, and run it long enough to heat up the oil well.
Reactions: Farmer
Farmer
Farmer
2,973
17,161
Southern MO
On a side note...the starter cranks way faster than it ever did.
Get your tailgate to lay flat by ordering new cables here... Longer Tailgate Cables For Honda Pioneer 700 & 1000
