P1000 Running wires for whips
Forgottenbb2
Forgottenbb2
11
60
So I'm installing some 5150 whips. I'm trying to figure out the best path to get the two harness wires to the front of the machine. Actually thought about running them up high along the cage to keep them somewhat dry but I've seen most run them through engine along the frame.
Coeus
Coeus
Major General
59,501
594,582
Signal Mountain, TN
  2. Talon R4 LV
I have mine run up high in the cage along driver side
JenElio
JenElio
65,216
610,105
Loxahatchee, florida
I'd say depends on your terrain mainly. I try to avoid the upper cage as much as I can cause I ride a lot of tight wooded areas and anything that can get snagged will get snagged. That being said.......sometimes you gotta what you gotta do. I wouldn't worry about trying to keep the wiring dry though. Them things are pretty well water proofed 👍
Good luck, post some pics when you're done 👍
WagginTail
WagginTail
1,475
5,462
SC
No whips for me but I do have pod lights on the back roll bar. My wires are in split loom on the top of the cage under the oem roof on the passenger side. Seem pretty well protected there
Glank
Glank
100
340
So, it wasn’t easy, but I ran my whip and rear light wires under the body along the frame like the tail light. The plastic conduit is exposed up under the frame until they hit the back of the front seat. They then route under the seat, below the front floor board and up through the the dash into the front. With all the clamps for the roof, windshield, vent tubes, etc… I didn’t want any more “stuff” running along the ROPs.
yeah, I know I need to clean it.
296756FB 4BFA 4A7B 9363 3EA798067C3E 552FA191 0C2A 4A62 8339 4CE665B2D5C3 5F2E75F6 C49D 4644 ADCB A106B6B2ACBC
