T
I have been chasing rust on my 2015 p500. Its not bad but seems certain places don't have a good primer so the paint just bubbles off. I clean and spot spray with rust reformer then black enamel. My problem now is the metal plate under the fuel tank is 75% rust and I cant remove it to repaint, its welded to the frame in two places. Does anyone now how to remove the fuel tank? I have tried to remove the tank out the top but it won't move to the center enough get thru the seat frame. I cant even get it back over and down to its original location. I thought it may help to remove the plastic side panel, so I started removing the door hinge bolts (panel is behind hing plate), with a lot of force I got the top one out using 5mm alen, the other three striped out the head of the bolt, would not budge even with manual impact driver.
