P700m4 RZR Shocks??
9dae7bddbc637efdfbdbe50f629546f8
Reactions: jak9922
283,012
Here is the ticket, it's only money and your kidneys will thank you:
1.5 PODIUM C Honda Pioneer 700 / 700-4 UTV Shock | FOX
Developed for the Honda Pioneer 700 and 700-4 the all-new 1.5 Podium C will be sure to handle any aggressive or casual trail riding without sacrificing any of the Pioneer's utility work ethic. Featuring high quality 6061-T6 aluminum bodies, 5/8" hard chromed shafts, and 2" lightweight springs. External tool-free compression and preload adjustment will let you fine tune the ride and handling to your personal preference, terrain and load situations.
Pioneer set 4
Reactions: Tflynn
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
Joey if you can find shocks that size and have it sprung to the weight of your ride ur golden if u like the valving of it but if its fox or name brand u can have them revalved for pretty cheap
283,012
Pioneer set 4
$1200 to do it right the first time:
Fox Shocks Podium 1.5 C Front Rear Suspension Kit Honda Pioneer 700 2014-2016
It will be trial and error so I want to R&D this for cheap. There are some guys in town that are huge into the RZR's so I'll go talk to them about it and see if they'll let me test fit some. I would rather keep my home made lift brackets for the lower mount vs spending a grand.
It would just be super sweet if someone (me) would put forth the effort to research and post a write up on what fits and what doesn't. Also, is it set up for the weight of a pioneer.
More to come...
Reactions: green02crew
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
Yes vehicle spec model but here is one example of money saving i had a customer i put a new 350 tbi motor in a 89 chevy 1500 he called me 3 mths later the starter crapped out (his stock one) so i said ok ill pick you up get a new one u buy it ill put it in no charge so we went to autozone and for an 89 1500 the starter was around 250 i looked at the clerk and said are you out of you mind give me a starter for 89 camaro which was 100 guess was same damn starter!!!!!!!! My point is you might be able to find the same thing for less just for a different app
Reactions: joeymt33
BTW, I don't care about the brand. I've never been that guy. I'm just looking for cheap pull offs that will be better.
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
Brand name doesnt really matter but its the level that brands are on does that make sence walker elks fox all are same level while kyb showa another
Yeah, stock shocks suck....wow, say that 5 times fast.
283,012
Ive made alot of money from ppl paying more the first time but its not always right lol
Perhaps, but suspension valving, rebound and damping are tuned to the weight and geometry of the suspension for that specific purpose. Just because the bolt holes are "about" the right distance apart and it has a spring on it does not mean it fits.
If suspension is not working for you its worth doing properly for the sake of a quality ride and safety. A snapped shock shaft 30 miles from BFE and a tire you cannot stop from rubbing your frame to get in is not worth any "good deal". Just saying, people spend $1200 on a windshield, roof, and bumpers and don't bat an eye and they add little actual comfort when it rains or gets cold. Proper suspension works every minute you are moving. What's the best deal there in $ per minute of operation.
There's a lot of truth in your post Jackal but I haven't found a set of shocks for a pioneer that has added a couple hundred pounds and wants to lift it at the same time.
Also, I'd hate to drop a grand in this ride if I'll be getting a P1000 soon. Crap, I'd hate to know what I've got in it so far. I can't add it up because if I ever come up with a number, my wife may find out. She already fusses that it costs more than her SUV. She doesn't have a clue what the accessories cost.
What's a popo 900 weigh any way? Are they around 1000lbs or a little more? The 900 shocks may be too soft for a 1500lb vehicle.
283,012
Also, I'd hate to drop a grand in this ride if I'll be getting a P1000 soon. Crap, I'd hate to know what I've got in it so far. I can add it up because if I ever come up with a number, my wife may find out. She already fusses that it costs more than her SUV. She doesn't have a clue what the accessories cost.
If you communicate with the vendor what your particular setup is FOX with ship the shocks with heavier weight springs to compensate for the added weight. For the price they should be setup to fit your particular application.
Reactions: joeymt33
Going 3" longer on the shocks, if they do not compress at a static setting as much as the OEM shocks it may bind your CV joints due to the increased angle. One way to test would be to lift / hoist your Pioneer off the ground undo the shocks and let the a-arms droop to 22 3/4" at the mounting brackets and see if there is any binding as you rotate the tire.
Don't forget droop, when the suspension is uncompressed because that wheel is off the ground. Especially as much airtime as you get.
Reactions: Tflynn
People are using the rear shocks... Think they are shorter though.
Tflynn
Tflynn
Not a liberal
2,501
3,834
Northern California
I know 1200 is a lot of cash but the way I justified it is with this simple fact- if your wheels are rolling, you're using your suspension! I've got at least 1200 in other stuff I rarely even use (winch, lights, etc.). Granted these are things no rig should be without, just making a point. On the other hand if you know you're upgrading to the 1000, then I totally understand going for a cheaper solution
