SATV 400 Watt Universal Steering Kit Install
104,908
@PaulF when you tied into your oem dash light with relay and tied into your harness plug. Did you take out the Oem Ecu completely?
Thanks,
I dont think he did? But he hadnt been on since August 2022 since he started helping SATV on the PS R&D. Maybe send him a PM he might respond
Reactions: Smittyp
Blaker3115
Blaker3115
52
208
Ok thanks, I was just curious if he left the connectors hooked up to the controller for the information sending from PCM to oem power steering ecu was relevant for the vehicle speed sensor to tie in for the blue wire on kit.
I’ll try to send him a PM thanks Remington
104,908
When we did it to our talons and My p5 you didnt hook the blue wire up.
Blaker3115
Blaker3115
52
208
Well its all complete with wiring and plastic molded around the motor and ECU mounted in the OEM original location under hood close to the power steering motor. I chose the same route as @PaulF went with going through relay and oem dash light for if easier troubleshooting of the superatv light of ez steer. Hope this info helps someone going down this path and I will update with more videos and pictures as I hit the rock climbing trails.
Blaker3115
Blaker3115
52
208
Ca6e97fb87ed54e71ee307462d35af97
C1f8581ab9bbe1e5602a92b5daa7e554
0fe6a97bb331ab1b6237e83993f1eae2
A52ca76e0b5ae4102dc5ae0c001871c8
Here’s what’s to come to truly test out the steering upgrade!!
TerryH
TerryH
664
2,241
Springdale, Ar
Reactions: Smittyp
56,658
32” is what’s on it now. The zillas are 35”.
I’ve got the IGR 25% reduction and talon reverse upgrade in my pioneer. With FCP tuning.
Let us know what you destroy. Few of us have been on this adventure before but it was 32" Zillas at @snuffnwhisky expense, back before it was cool to have Zillas 😂 . @joeymt33 found all the weak points, snuff fixed them all, then parked the old girl in a field to die....
B7Tn7kWrkgZegnOCQf1Maf4Aw703 h937 s noauthuser0
