Secondary batt
sspeederr
sspeederr
391
661
I finally got around to installing my second battery i made my own batt box out of scrap metal laying around not running an isolator at the moment but its in
20201025 151751
20201025 151756
20201025 200236
Reactions: Mudwing and TxDoc
5,715
26,179
What's that silver thing above and to the left of the battery under the cowl (last pic) - LV something? That's where my aux battery will end up (copying PaulF) but it's a low priority.
sspeederr
sspeederr
391
661
Don't QUOTE me on the but I believe it is the live valve computer my buddies 19x does not have this computer here
Reactions: CID
CrosbyTalon
CrosbyTalon
59
117
Minnesota
Anyone think about putting a battery in back to help with weight distribution? The talon is nose heavy and after a winch and in my case a plow mount I would prefer to keep it in back. maybe where the factory airbox used to be?
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
Talon is nose and slightly left heavy. Talon Race Team either added or moved theirs here if water/mud is not an issue for you...
1603747221286
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
good spot Paul! You are like Sherlock Holmes when it comes to pictures and videos!
If you are concerned about water/mud/dirt, you could also consider putting the battery in a box. I found the metal ammo cans at HF are water tight and fit like a glove between the engine and the suspension on the R. I use mine for tools but you might be able to fit an SLAA12-35C battery in there...
20201026 172644
Reactions: Mudwing and TripleB
CrosbyTalon
CrosbyTalon
59
117
Minnesota
Very nice! I think I will be fine until I add a heater next year. Then I may be pushing the limits of the system plowing with heater on,heated seats, music, light bar, winch, and hydro turn all working when its cold out.
Reactions: TripleB
