P1000 Shackle on OEM front bumper
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
for those that have shackles mounted on their front bumper, how much pulling have you done on them? I got a few shackles recently and trying to decide on a mount. But before I go through all that, id like to know how well the bumper will hold up.
322,689
I welded ours on and through the bumper to the bumper mounts. I'm sure you could pull anything the winch can put out
IMG 0980
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
I get stuck... I can’t resist a little mud. Even though I should
Reactions: Fomocowboy and BWAF
ToddACimer
ToddACimer
Pioneer 1005-2
3,659
15,383
Oshkosh, Wi
I pulled on mine with a snatch block. Probably not the full winch rating but over 4k for sure. I also used mine as a front trailer tie down.
15192531 10100563275563117 352336562634053615 n
173,625
Fat fender washers backing them, pulled me out of a mud hole using a snatch block. Don't know that I'd go tugging and yanking on them too much though.
Newest front
I’ve stalled a Warn 4000 lb winch using dual batteries and a snatch block. Also they are great tie down attachment points.
A4a9897bade971ef7b876a2082b6bee7
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Reactions: Mobius396
Reactions: bigdeal
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
May have to pick a set of these up
Im leaning towards those as well. Others are using cable clamps and having success. My only concern is pulling on an angle with that compared to having the plate.
urbancoyboyja
urbancoyboyja
Buckle Up, I Want To Try Something...
182
389
WV, USA
That’s exactly what I did and have had no issues!
Same here. No issues with that set up.
Reactions: Tramguage1
1BadDart
1BadDart
1,411
12,981
W. KY
Here's what I did for @nbomar.
Heck I even tried to Camo them.
These are plenty strong for what our machines weigh, a lot stronger than what they're bolted to and can be had for less than $10 each around here. As mentioned use a support plate behind the bumper and IMO stay close to the the factory tubes that make the bumper mounts.
Reactions: CumminsPusher
Tramguage1
Tramguage1
Texan
7,379
29,692
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
That's how we mounted them, as close to the tube that goes inside the frame. I would suggest drilling the holes a 1/4 from center line of the backing plates. That way you can flip them around side to side or end over end to get it as close to that tube as possible. Also I drilled them while clamped together to make sure they worked in any position or side.
Tramguage1
Tramguage1
Texan
7,379
29,692
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
You will want something to dampen the noise! @nbomar said they were noise. We just ran a tie wrap between the pivot point and tha helped, maybe a piece of rubber tubing under the front clamp.
