P1000 Shifter Mod
William
William
1,442
2,887
Flowood MS
Has anyone taken a dremel to the bottom of the shift gate to give more throw for low gear engagement? My shifter is adjusted correctly, but if I’m nice to it when shifting to low I will get the - and very light grinding. If I go to high first, then go to low more roughly, it’s fine.... At this point, I am almost certain I don’t have gear problems... Never have had the loud bang or any loud grinding. Any thoughts on the dremel idea?
TripleB
TripleB
11,695
99,309
Caryville, Tennessee
I've been getting the same thing as you. I keep forgetting to check my cable adjustment so mine may be out. Let us know what you do and if it changes anything.
Reactions: Lady01
William
William
1,442
2,887
Flowood MS
Just thought about something, from when the dealer did my recall inspection, the sub trans still has conventional oil in it... I had no problems before that, but it had synthetic in it before... I’m going to change that and see if that helps any...
Reactions: Lady01
William
William
1,442
2,887
Flowood MS
I think I’m just going to take a razor knife to the circled part this evening....
2783A2CD 8449 4735 9899 53E84D82036B
Reactions: Lady01 and TripleB
William
William
1,442
2,887
Flowood MS
Well, I bet I won’t have this problem anymore... So I just took a piece of 80 grit sandpaper and took my time. In about 10 minutes, I had it down to my liking. About a millimeter from the metal plate behind it. It gave a lot more throw on the shifter. Then I changed the oil to synthetic, and adjusted the shifter to where it had more slack towards reverse than high. If that makes sense... So I should never miss low again!
3470129D D24A 4510 A028 B5BFD75D6D1E 360C176D F855 4A6A B380 B9A7E2215F77
