P1000 Shock or front cushion question
Mopower58
Mopower58
CST is the Best!
79,418
706,154
Crystal Springs,Ms.
Has anyone tried the Rough Country shocks?
There is a thread on here about some peeps using them. 3 or 4 use them I know. I'm no shock guru so I've been eyeing those also for the spring preload ability as I don't care about compression and rebound adjustments.
115,291
Thanks. I’m just not in need of fox or anything like that. Just don’t go on many rides anymore.
Why dont you buy some elka stage 1’s then. You can have them customize to your riding, and I believe u can get a forum discount as well.
Mopower58
Mopower58
CST is the Best!
79,418
706,154
Crystal Springs,Ms.
Elka built in Canada verses Tn. USA........Elka Stage I 1500.00 set.........Rough Country 700.00 set.
115,291
Interesting. When I looked, there were close to the same price. Must have looked at non comparable models
Reactions: Mopower58
208,725
Both are coil over.
Yes, but that's all I know cause I've never used Elka 1's or the RC shocks on a P1. What I do know is the stock shocks are junk and anything will be an improvement! I'm a suspension junkie and went with the Elka 5's, I wouldn't recommend that, unless your crazy.
