P500 Shocks
drrjv
drrjv
59
Delaware
Just picked up a Pioneer 520 last week and already looking to do upgrades.
Looked at previous posts on aftermarket shocks and wondering if these would be a good option:
Newsmarts 2pcs Adjustable 320mm Motorbike Air Shock Absorbers Universal Fit
Fitment
Universal Fit Street Bike, Scooters, ATV, Go Kart Shocks. Work perfectly on most 150cc~750cc street bikes, Scooters and Moped Quad (ATV) with shocks of 320mm eye to eye distance. Great choice for replacement, style upgrading and all kinds of bike modification.
View attachment 41231View attachment 41232
Specification:
Condition: 100% Brand New
Total Length: 350mm (13 3/4")
Length of Eye to Eye Core: 320mm (12 5/8")
Eye Diameter(with bushing): 12mm
Eye Diameter(with bushing removed): 16mm
Eye Thickness: 21mm
Eye Maximum Tensile Strength: 2,000 Kgf
Spring Thickness: 7mm
Spring Width: 60mm
Working Stroke: 60mm
Spring Stiffness: 110 kg
Maximum load: 200 kg (≈440 lbs)
Air Reservoir: Adjustable
Factory Air Pressure: 0.4 Mpa
Maximum Air Pressure: 0.5 Mpa
Link:
drrjv
drrjv
59
Delaware
Welcome from west GA, the 500 / 520 guys seem to like Elka stage ones. Where's the pics
#NTC
Thanks, I was looking for something at a lower cost
2FC94710 A332 4C1F 8FB2 37043B4B3F4E
105,440
Check the original post. Not sure if they would work or not
Like what @trigger said, there for a moped that will ride like $hit lol.
Theres been thousands of threads on here for alternate options for shocks for P5’s and 10 out of 10 times they end up with the main brands, Elka and WE’s. Bronco shocks seem to be closest to what your after but I believe they weren't all that happy in the end. You can search it all up top and use threadloom results, and read till your harts content lol.
Mark in Northern Iowa
465
2,078
Floyd County, Iowa
kramnella.wixsite.com
Howdy and welcome from Northern Iowa.
I see you made it over here from the other place.
These guys are gonna give ya heck, especially that @Remington guy. hahaha!
But, the knowledge is here for you to receive.
Some of these guy have 10s of thousands of miles on there Hondas.
Always try and help yourself first. The search bar does work well.
If you can't find what you are looking for, change your search wording.
WT....., just did a search "520 shocks".
Second thread down says the 520 shocks are adjustable.
I wish mine were adjustable, lucky son of your mother....hahahaha!
Have a good day
208,013
Fitment
Specification:
Eye Thickness: 21mm
Spring Width: 60mm
Link:
Welcome from NW Arkansas!
crewcabrob
crewcabrob
1,029
4,038
Omaha
I personally don’t see a need for aftermarket shocks on the 520 with such little amount of travel. I know Honda updated the valving over the 500 shocks
I totally understand what you are saying, but you could also look at it like; there is only 5.9" of travel and I want it all to make a difference. :)
Dave75
Dave75
123
500
If you drive slow, there is no need for aftermarket shocks. The front p520 shocks are bad. Here is a photo of the stock front next to a WE shock. Over the same trail, I can drive faster with the WE shocks. The front shocks are great for work, there is very little sag. I am saving the stock for snow plowing.
852D7377 D105 4CA3 ACDF 4613566AE176
NTCPrezJB
NTCPrezJB
President of #NTC
100,471
898,020
Canton, OH
Look at the max load on the shock you posted. Consider your SxS weighs something over 1k pounds. Factor in your weight. Factor in a passenger’s weight (if applicable). Factor in your load/gear weight. That gets you to the static weight load. Now bounce up and down on your bathroom scale and see how high your weight bouncing on that scale gets to. Jump an inch or two in the air and see what that scale spikes up to. Those max fluctuations are your dynamic load. Consider from there what you think that type of dynamic load would be for the entire weight of your static SxS load you calculated earlier.
Long story short….I’d bet you’re going to blow out those shock seals in very short order. IMHO…don’t waste your time or your money.
Welcome to the forum from Canton, OH!
Red is the fastest color!
Pics or it didn’t happen!
#NTC
Ridinfool
Ridinfool
36,145
386,039
Western North Carolina
#NTC
Prezzz gettin all Scientific and chit… 👍
#NTC
Buggyman
Buggyman
34,091
292,036
ne. ohio
Fitment
Specification:
Eye Thickness: 21mm
Spring Width: 60mm
Link:
welcome from Ohio
Dave75
Dave75
123
500
#NTC
Where are the posts for WE shocks that have blow out seals?
