SLOWPOKE goes short course racing
BlueLV21
BlueLV21
6
20
Show Me
  1. Talon R LV
Too be honest, I loved my XX. Very quick for the weight, fantastic handling. But, the weight obviously hurts them, even though they are quick…but the reliability is what killed it for me.
SLOWPOKE693
SLOWPOKE693
2,010
7,790
Somewhere in Texas
Zoom zoom...
20211202 181835
20211202 200701
20211211 124131
20211211 123357
Just waiting on a set of bronze valve guides and the spring/retainer kit to show up later this week and then it's all getting shipped up to Missouri for the build.
Due to the extended time frame needed to get certain engine parts custom made for the build I decided to go with mostly off the shelf parts and race fuel for next season so I don't miss any races at the beginning of the year. We still plan on bringing the car up to PPEI for dyno tuning and while it's there they will be adding the launch control feature so Slowpoke can get some holeshots next season. 😁
Other than throwing it on scales at some point this winter to make sure it meets the new 1700lb minimum weight rule I don't plan on changing much else.
SLOWPOKE693
SLOWPOKE693
2,010
7,790
Somewhere in Texas
I hate to admit this but.... I haven't even tried this feature yet (-:
You have WAY more self control than I do!
I probably would have tested that feature in the parking lot of the Honda dealer before loading it and taking it home if my 2019 came stock with it. 🤣
211,609
Ya, me too..... Some good things happened and plans changed again a few weeks ago, so here I am again. 😁
I hope you get things sorted out before the season starts! That's a pretty radical change! Reliability will be the question?
Reactions: toddvdh
SLOWPOKE693
SLOWPOKE693
2,010
7,790
Somewhere in Texas
The turbo Talons are not breaking at the HP levels we are shooting for, so I don't think we will have any issues as far as reliability goes.
We've been told the engine side is good (with pistons) for over 275hp per hole.
Its the clutches that were the issue in the past, but i think guys have figured out how to make them last by removing the traction control functions in the pcm programming. It was seeing wheel spin and slipping the clutch causing it to fail.
SLOWPOKE693
SLOWPOKE693
2,010
7,790
Somewhere in Texas
The new transmission/abs programing that's floating around the race scene pretty much solves all the clutch problems. I know Dr Powersports is running a highly modified Jackson kit along with the special trans tune on his race car and isn't having any clutch issues that I've heard about.
Brazula4life
81
97
Florida
Figured I'd start a thread about my racing adventures this year in case anyone is intrested...
This is the car I built over the last year. It's a 2019 R model that I cut up with 60 miles on the odometer......
Where are your shocks and spring? I only see the square tube there?
Also what was your ride height after getting your shocks worked on by George white? I want to get my lv done , but it is quite expensive.
I do rallycoarse now I only have their sway bar which works awesome, but the car still body rolls alot.
