Talon Schmidty Racing Talon X-4 build..
SchmidtyRacing
SchmidtyRacing
20
57
Central California (for now!)
www.schmidtyracing.com
Time to start the build..
Here are a couple reposts from the maiden voyage.. Got a few boxes coming in .. Christmas in October!!
11633FB9 82B6 40AC B48B 3BB9E42C03BD 4303E62A 595F 4C42 8A80 78A322051520 533A18A7 7C8D 419F 9ABA 0FF1F12D2866 E3C78EDB 1025 406F 9D6A 263098E4B2A5
SchmidtyRacing
SchmidtyRacing
20
57
Nice. Looks like Tusk Terrabites. What diameter are the tires and wheels and which wheel offsets to did you pick? Using spacers on the back?
The wheels are currently only avail in one offset 15x7", 3.5 +3.25 Offset, 4/136 Bolt Pattern. Yes, the tires are the T-TB, and are 32's.
Eventually, I plan on widening it to "R" width , so will build custom arms to correct the imbalance width issue at that time, as I am only running one rim width.. I despise wheel spacers, so I will live with the issue till I get that done..
SchmidtyRacing
SchmidtyRacing
20
57
Had to get the wifes horse hay stacked inside before weather today, so I didn't get to work on mounting tires much today. And yesterday I replaced all the equalizer hardware on the flatbead as it was shot.. I also didn't have a 12point 8mm, for the beadlock rings, so I also had to make a run to Lowes fo that. I did get two tires mounted, and at first, I just set them up against the car for pics.. But I just couldn't stand it, and had to mount at least 1. They change the entire look of the car. I am pleased with my choice looks wise!! I hope they perform equally well!!
IMG 20351 IMG 20341 IMG 20441 IMG 20451 IMG 20481 IMG 20471
TerryH
TerryH
664
2,241
Springdale, Ar
View attachment 163371 View attachment 163374 View attachment 163387 View attachment 163389 View attachment 163391 View attachment 163393
32's look and work so good on the Talon. Like they were made for them.
Sheetmetalfab
Sheetmetalfab
2,113
13,165
Alaska
how it it in tight slow technical terrain?
I’m assuming low range and 4wd.
does it make the power application like a rubber band?
jamesh
jamesh
253
350
DFW
Can you show a pic of the clearance between the tire and the wheel well with it turned hard right or left with the machine set.down?
Reactions: GregMorenoAZ
jamesh
jamesh
253
350
DFW
Schmidty, have you had a chance to ride with the new tires/wheels? I'm curious if you have any tire rubbing with that 3.5 +3.25 offset and also how it handles with the offset.
