P1000 Snorkling the Pioneer 1000!
You going to snorkle your p1000
  • yes
    Votes: 59 78.7%
  • no
    Votes: 16 21.3%
  • Total voters
    75
Scooterchris
No longer active.
Dec 25, 2015
396
237
which route did ya take
Cup holder. Did a little diff on the piping tho.
1455680289375
Reactions: marinemike
Scooterchris
No longer active.
Dec 25, 2015
396
237
Used a standard Ole 90 degree elbow at the top
Find the 22 degree elbow to make a slight bend in the middle
Scooterchris
No longer active.
Dec 25, 2015
396
237
and u stuck the rubber connector in the intake hole? guessin two 90 degrees are needed
I stuck the rubber connector in the intake hole and put cement on it. The 3" to 2" rubber connector was a pain in the balls wouldn't go over the intake tube. The 2 inch pipe I used left to much of a gap for my liking to just use cement and be done
When I change my body panels I have to do it again so this time I might heat up the 3" to 2" connector and try again
mikegzales
mikegzales
61
68
louisiana
going to get parts tonight
Reactions: Scooterchris
Scooterchris
No longer active.
Dec 25, 2015
396
237
Parts list: 35 dollars total I believe
Used about a 5 ft stick of 2 inch pvc
Can of black spray paint
2 - 2 inch to 2 inch rube connectors
1- 22 degree elbows
3- 90 degree elbows
2- 45 degree elbows
Pvc cement
Dremel tool
2 manly zip ties lol
Take door off
Take black fender off
I used cup holder. Just cut bottom off to maintain descent look. Don't cut to far. You want to keep the clips on cup holder.
mikegzales
mikegzales
61
68
louisiana
1- 22 degree elbows
3- 90 degree elbows
2- 45 degree elbows
Pvc cement
Dremel tool
Take door off
thanks
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
I disagree. It was 80 degrees this past Saturday here in Florida. About mid day I shut my machine down to check the sub trans bellow. I did not hear any pressure being released or my dipstick didn't shoot up. It was fine. Great news is it worked. No water got it
didn't you go with the Polaris (softer material) bellows?
