Which soft doors might fit best with a SuperAtv flip up winshield if any??
CEC enclosure is what I'm probably gonna buy this winter. They are only on Facebook.So I have the SATV flip up windshield and that appears to lock me out of selecting the Seizmik soft doors. Based on research Seizmik was my #1 selection. #2 appears to be Honda. Any feedback on the new Honda uppers? or is there another good soft upper that I am missing?
I've got the updated honda soft fSo I have the SATV flip up windshield and that appears to lock me out of selecting the Seizmik soft doors. Based on research Seizmik was my #1 selection. #2 appears to be Honda. Any feedback on the new Honda uppers? or is there another good soft upper that I am missing?
Looks like a well made product...I just don't want to have to unzip every time I open door.CEC enclosure is what I'm probably gonna buy this winter. They are only on Facebook.
I've got the honda hard coat 2 piece on now. I'll be switching to the satv flip when I get the chance. The way the plastic shielding meets the a pillar there shouldn't be any issues adapting it to fit with the satv windshield. I've already notched them to fit with the chupacabra mirrors.Ohio4x4 what type of Windshield do you have on with your Honda uppers?
Thanks for your response. Much appreciated. I'll being going with the Honda uppers and the fabric enclosure behind the cab as well.I've got the honda hard coat 2 piece on now. I'll be switching to the satv flip when I get the chance. The way the plastic shielding meets the a pillar there shouldn't be any issues adapting it to fit with the satv windshield. I've already notched them to fit with the chupacabra mirrors.
Jack, Checking if you bought the Honda Soft Fabric upper front doors as that is my combo as well. I have the SuperATV flip windshield and want to buy the Honda soft upper doors and Honda Fabric mid-panel. If so how did they mesh up?Thanks for your response. Much appreciated. I'll being going with the Honda uppers and the fabric enclosure behind the cab as well.
I went with the Honda gen 2 upper doors and Honda mid panel. The combo works well, I did ditch my mirrors for a more simple install, I have a rear view anyway.Jack, Checking if you bought the Honda Soft Fabric upper front doors as that is my combo as well. I have the SuperATV flip windshield and want to buy the Honda soft upper doors and Honda Fabric mid-panel. If so how did they mesh up?
View attachment 243864 View attachment 243865
I have the exact same set up as russ. I rode windrock all day today and I never put on a jacket. I also have my access panel under the dash removed so it puts heat in the cab also.I went with the Honda gen 2 upper doors and Honda mid panel. The combo works well, I did ditch my mirrors for a more simple install, I have a rear view anyway.
View attachment 243866View attachment 243867View attachment 243868
I removed my access panel as well, it’s a comfortable ride. I kick on my fan override every now and then to get some extra warm air.I have the exact same set up as russ. I rode windrock all day today and I never put on a jacket. I also have my access panel under the dash removed so it puts heat in the cab also.
My wife is always kicking on the override to warm her feet. Its definitely sweet having that switch.I removed my access panel as well, it’s a comfortable ride. I kick on my fan override every now and then to get some extra warm air.
I like them as they lock up pretty tight and the mid panel fits really snug as well. I do not have rearview mirrors on the outside of mine so did not have to deal with that aspect of the install. I see your from ND so know your going to be in the cold. I took square foam lengths used to insulate around air conditioner to seal around the top. Glued two together and made a slit along the bottom and slipped it over the top of the windshield to seal above that. Also used a couple different kinds of stick on weather seal around doors and windshield. Drilled small holes and used plastic push pins to attached the seal around front and bottom of doors. Probably cost about $75 all in but really worth it otherwise thereis just too much air flow coming in. Pushed snow yesterday in my shirt at about 20 degrees.Jack, Checking if you bought the Honda Soft Fabric upper front doors as that is my combo as well. I have the SuperATV flip windshield and want to buy the Honda soft upper doors and Honda Fabric mid-panel. If so how did they mesh up?
Thanks for the update, I ordered the Gen2 Honda doors and mid panel. I was doing the same, researching foam "gap" fillers to seal it up a bit more.I like them as they lock up pretty tight and the mid panel fits really snug as well. I do not have rearview mirrors on the outside of mine so did not have to deal with that aspect of the install. I see your from ND so know your going to be in the cold. I took square foam lengths used to insulate around air conditioner to seal around the top. Glued two together and made a slit along the bottom and slipped it over the top of the windshield to seal above that. Also used a couple different kinds of stick on weather seal around doors and windshield. Drilled small holes and used plastic push pins to attached the seal around front and bottom of doors. Probably cost about $75 all in but really worth it otherwise thereis just too much air flow coming in. Pushed snow yesterday in my shirt at about 20 degrees.
