OK, I'm trying to finish wiring my aux and work lights. I have been trying to follow Honda's instructions for the work light harness. You would think that they would have provided the more straight forward approach, right? Well Step #2, remove the following:
- Seat cushion and backrest = NP
- Seat bottom cover (left only) = NP
- Seat Rear Cover = NP
- Rear floor cover = not fun: halfway through all the plastic connectors and drilling out one unmovable Philips screw, I said "whoo!" Still had to disconnect hand brake and more! Then:
- Front Floor Plate
- Front Floor cover
The harness is suppose to run right along the existing main harness and wire tied in numerous places. OK, why not just remove the two skid plates? I drove it up on ramps and easily removed the plates. Running a harness along from underneath was easy. I still have to tie wrap up and finish connections. But this is certainly a much easier approach. Added bonus is you get to clean out a bunch of crap that the pressure washer never seems to get.
- Front Floor Plate
- Front Floor cover
