P700 Sound system power
Benjy
Mississippi
Is it possible to run the power for my sound system to the block between the winch and the battery. This block is tied into my ignition switch. Currently I have the power from the winch system block, the sound system and a trickle charger all on the battery. It is a little cluttered and I want to move the sound system power to another power supply. Thanks for any help you can offer.
Russ989
Russ989
22,642
147,257
What are you calling a block? If it’s your winch solenoid contactor I personally wouldn’t do it. For best results you should add another battery.
Benjy
Mississippi
You are correct Russ 989. I am just going to leave it on the battery for now and plan on adding a second battery later. I just have to figure out where to place a second battery. Looks pretty tight on the 700-2.
Reactions: Russ989
