Talon Spare Tire Opinions?
Fusefinder
Fusefinder
Germantown Ohio
I have the 2019 Talon X and am looking to add a spare tire setup. My thought was use a take-off of the factory front tire 28 x 9 this should fit front or back and have clearance either location.
This is what I did on my last ride and worked well, I rolled 1 tire off the bead and came seriously close to rolling a second at Rush off-road.
Any options on the spare tire size?
If any of you who have upgraded tires and wheels and willing to part with one or a set please IM me.
Thanks
HUCK
HUCK
1,047
2,319
ARIZONA
I bought a set of take off wheels and tires . So I have a spare and a full set of replacement wheels and tires ! Prior to buying the set I bought a spare from a major supplier who advertised it as 2019 TALON SPARE WHEEL AND TIRE . Yeah well it fits but the Honda lug nuts don't work on (which they didn't tell me) so you couldn't use it without carrying a spare set of nuts and a different lug wrench !
  • Wow
Reactions: CID
SClever
Galion ,Ohio
I have a spare front and rear take off I'd part with. We cut two sidewalks within the first 200 miles ( front and rear) and decided to put the money towards upgraded tires/wheels instead of replacing stock tire. They didn't seem very durable, maybe just bad luck I dunno. I will be riding at Renagade Ridge this coming weekend and can bring them if anyone is interested
rbtnt
rbtnt
76
60
SClever - sending you a PM
W
Wigglysqiggly
73
146
Phoenix
I just bought an attachment from ebay and added to my rear bumper. I like this option as you still can see and still use your cargo area
C6069829 F459 45A3 99CA E6F0C4E3704B FB636ECC 6AC0 4AFC 8B2C 89E4E78F7F09 E22AA8B8 72DD 4D86 B391 129546570A92
Reactions: TalonRSM
SClever
Galion ,Ohio
SClever what set up with tires and rims you go with?
We went with ITP Blackwater Evolutions 30x10-15 on STI Hd9 5+2 wheels. The Blackwaters where very durable, but also very hard and stiff. Just this week I switched to System3 XTR370’s in the same size. I haven’t got to try them out yet though
208,726
15 inch rims caused the stiff side walls. I had a set of Black Waters on 14 inch rims, they flexed nicely with 10 PSI.
SClever
Galion ,Ohio
We aired down to 10 psi and had two pinch flats, went back to recommended pressure and they were tough as nails but hard as a rock. The Blackwaters have very stiff sidewalls and the rubber compound is very hard compared to other tires I’ve had. I’m sure the 14 vs 15 helps
TalonMatt
TalonMatt
71
148
WA
I picked up a set of take off’s and run the front tire as my spare.
1AEB369B 4105 4124 B0B0 5DC19D9EB5B1 B1EAFBEE D0BD 4174 A17C FBFACFD58ACA
Reactions: Iowamike
