P1000 Steering wheel
322,690
3E263B27 647E 48B1 92CD 1A14CB6B9921
Pick your 6 bolt wheel. 350mm is very close to factory. 320 works good too but paddles stick out a little. We were 50/50 with what we liked better. I’m going back to the 350 but there’s less choices.
Btw I’m nearly positive this setup will work on Talon and probably would on 500 and 700 as well. If someone tries it report back if you would.
JDM 6 Hole Steering Wheel Hub Adaptor Racing Kit for 92-96 Honda Prelude BB2 | eBay
NRG STEERING WHEEL SHORT HUB ADAPTER 92-95 CIVIC PRELUDE INTEGRA ACCORD SRK-110H | eBay
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/222578620664
REVISED.CHEAPER SHORT HUB ADAPTER CANT SEEM TO BE FOUND ANYMORE. THIS IS SLIGHTLY MORE MONEY BUT WILL WORK AS ADVERTISED.
I believe this is correct list I will check exacts tomorrow, it’s late
Steering Wheel Short Hub Adapter Billet For Honda Civic Accord Acura | eBay
That’s cool, can the horn actually be connected to work with a UTV horn? Are both adapters and spacer that you linked to required for this?
322,690
It can be but takes a little work
Reactions: sharp
322,690
Thanks I got it all in my cart. Let me know if anything is missing and then all order it. Thanks for the help.
Everything looks good. The first item in that list you’ll use only the black boot off of that hub assembly so if you find a steering wheel combo cheaper that has that hub you don’t need to but that part separately. Obviously hub fitment doesn’t matter since you’re only using the boot.
The horn button is fairly universal so can find a Honda one or Momo etc. there are various colors of each so whatever there but I just picked out reasonably priced black.
Reactions: sharp
322,690
@CumminsPusher Did you post a link to the spacer ring?
You’ll need the spacer ring to make room for the horn button.
I did this time thanks for reminding me:)
Reactions: sharp
Neohio
Neohio
Beast of the East
14,586
73,811
Painesville Ohio
In the original PJ thread, You ground down a piece from one adapter. Not sure if that needs to be done with the current selection you have linked.
322,690
It does but it’s simple. Pics below. With this parts list nothing on the pioneer needs to be modified.
64E72EDB BB3B 4324 81DF D9CFBD8FED6F
AD50890E FDF2 4C10 9A7A BCE5C0966CB5
322,690
I didn't want someone to get caught is all.
Thanks for the pics!
That’s a good call. I wish could find one reasonable that doesn’t need ground. If someone needed I’d have no problem throwing a quick grind and sending it back out.
Reactions: sharp and seig
