P1000 Steering wheel
Neohio
Neohio
Beast of the East
21,761
93,350
Painesville Ohio
Neohio
Neohio
Beast of the East
21,761
93,350
Painesville Ohio
Nope.
Need one for the earlier generation.
Use 92-96 Prelude for correct fitment.
Mine should be here any day. It should be the correct one. If it is, I will share the link. I looked at 50-60 ebay listings to find it.
RedFred1
RedFred1
301
619
North Carolina
Done and done...
3714B906 B7FC 471E 8135 530F6E2A7DBC 2E9FA8D5 8CE9 41E1 A6DD AAE2287E84E0
A
Average_Joe
970
3,676
Gainesville, Fl
  2. Other Brand
I swapped my steering wheel out using the NRG hub adapter the factory nut is too tall to put my center cap on. What nut is being used a 1/2 height?
Reactions: BWAF
BearWoods
BearWoods
92
260
53
East Stroudsburg, PA
In order for the lock nut to stay in place, you want to be sure it threads on far enough for the nylon in the threads to grab and hold the nut in place. Vibrations may otherwise make it come loose, and back off .. that could be scary. I ended up grinding material off the back side of the NRG adapter to get the nut to thread on far enough to hold and to put the horn button cover on.
Reactions: BWAF
Did you use the horn button spacer listed?
Reactions: BWAF
@russknight
This is how I did the horn button. Take a horn roller from an old car (this was from old Dodge truck) many older cars prior to 80’s had them. I used a two part epoxy to fix it in.
Horn then has positive wire hooked up, either through ignition or direct with fuse. The negative get hooked directly to the wire off the roller. It’s really simple and once in the rubber collar protects it for the most part from the conditions.
I figure if this setup works for 50 years in an old truck it’ll do fine for a long time in a Sxs
6289298F AA68 4552 B2A6 F43037C9196B
8B28B080 D01A 4860 8F05 AE37C7C06C8A
A964B73F 351F 4B44 BB9B 92142EE6825D
Reactions: Mudwing
russknight
russknight
1,910
7,514
Perry Florida
I'm a little slow on the uptake, sorry. So, the horn roller goes underneath the steering wheel? And what completes the circuit? Is the steering shaft grounded?
Reactions: CumminsPusher
Yes. It makes contact at steering wheel adapter so the ground through the steering shaft goes through horn button and comes back through the roller and down the wire.
It just allows you to that that switched ground from the horn button through the steering column without a wire wrapping around stuff as you turn.
Reactions: russknight
russknight
russknight
1,910
7,514
Perry Florida
Thank you. I think my pea brain self gets it....
I never meant or implied that. Nah everyone thinks differently. Somethings some understand certain things, others don’t and vice versa. Things I don’t know I’ll ask or try to figure out most of us do.
If someone says they know everything they are full of s***. Nice thing about this site is its huge and there’s a ton of information at your fingertips, and not just Sxs related. Someone will have a good suggestion for about anything.
russknight
russknight
1,910
7,514
Perry Florida
Oh I know you didn't, and did not mean to infer that. I'm old now and my brain doesn't work as well as it used to, lol!
aauman88
aauman88
1,091
2,846
Know it’s an older thread but the links in the thread don’t work so was needing help. I want to change steering wheel and I know to get shallow one. I’d like quick release like @TerryH done on his talon but wanted to make sure I can’t see the shaft after replaced. Some seem to have a boot covering it and that’s way I want it to look if possible. If it’s not possible I will abandon the quick release and just go with a fixed one. Thanks
