P1000 Still a bit confused wheel size
Plumber101010
Plumber101010
597
584
Western NC (Hayesville)
Have the 4 original tires with no wheels
since I upgraded to diff tires pre purchase.
The upgraded tires are all the same size and are sitting on factory wheels all the same size.
But yet the factory tires are fatter in the rear. Not sure I like that but it is what it is.
So getting ready order 4 cheapie wheels just so I can swap back and forth.
But the 27-11-12 is substantially fatter than the 27-9-12 and wondering if I should get a wider rear wheel since I am at it or leave the stock wheel and I guess have this thing bulging and sticking out over the sides??
63,711
You are confusing us...
OEM wheels are NOT the same size!
What size aftermarket tires did you get? You said same size but you list 9's and 11's. (maybe you are talking about the OEM's tires)
FRONT is a size =
REAR is a size =
The OEM wheels are NOT the same size so YES will look different on the front vs the rear even if all 4 tires were 27-10-12.
63,711
Once you switch to the aftermarket wheel the aftermarket wheel/tire combo will stick out even more than they do now.
But all 4 will be the same and you can rotate them. Also makes it a easy decision on a spare.
Plumber101010
Plumber101010
597
584
FRONT is a size =
REAR is a size =
Well...dealer said the wheels were the same and Rocky Mount ATV who I just hung up with said they were the same. So now I'm even more confused!
But you misunderstood the tires. The upgraded tires are all the same (28-10) but the extra original tires I want wheels for are 9 and 11
Reactions: Hondasxs
Plumber101010
Plumber101010
597
584
But now that u said wheels are diff I am looking at it and the front tires do look like they bulge more than the rear which means diff!
320,170
They were talking height I'm sure
320,170
We all are
Reactions: Plumber101010
Plumber101010
Plumber101010
597
584
So make it easy on me :) I'm too confused now to figure it all out..
What wheel size for OEM tires I have at 27-9 and 27-11
Plumber101010
Plumber101010
597
584
LOL... those "exact" ones won't work. They are 4/110. You need 4/136 or 4/137 lug pattern.
See, this why it's all too confusing!!! Says specifically will fit 1000. But I dot i's cross t's and wrote seller an email and he said it would fit!
The world is full of misinformation!!
63,711
320,170
As long as the overall height front-rear match and it's not a negative offset like front wheel drives have where the face of the rim sits to the outside your good. The only difference between front to rear of the pioneer is width but the front hubs sit further out then the rear so the same wheel all the way around will result in the front wheels out as well. You could get around that by adding spacers to the rear so they'd all be the same.
Plumber101010
Plumber101010
597
584
Sent Messages
Product details inquiry from Amazon
Send To: KJ Motorsports
The wheels you have:
Raceline Mamba ATV Wheels/Rims Black 12" Honda Pioneer
It says 110 pattern. The Honda Pioneer 1000 has a 4/136 or 4/137 pattern.
Are you shipping the 110 as listed or you are aware of the difference and in fact shipping the 136/137?
***Sounded like a pro I did thanks to you:)***
Reactions: Hondasxs
Plumber101010
Plumber101010
597
584
Reactions: Hondasxs
