Multi Strapping down your SxS
13,363
65,125
Does etrack include mounting specs so that it's anchored well enough for all load locations? I mean does it require a crapload of holes or what?
I believe E-track has holes every 3 inches along each side of the track. At a bare minimum, I would use nuts and bolts every other hole alternating side to side.
Farmer
Farmer
2,851
16,389
Southern MO
Ouch! Thats probably not going to happen then. I don't think I could bring myself to drilling that many holes in an aluminum trailer deck. Besides, if I remember correctly, I think there's a bazillion ribs under there to contend with.
nbomar
nbomar
4,416
17,854
Springdale, AR
I use cargobuckles on the front bumper d rings and on the rear hitch safety chain holes. 4 cargobuckles. It doesn’t move and I can be strapped or un-strapped in about 60 seconds. I used the over the tire method also in my toyhauler because the d rings in the floor were known to rip out of the floor or break. I used to hook to the control arms for a more horizontal pull and to allow the suspension some flex but I think this could also be why my front lower arm bushings were toast so fast, so I changed my method.
Reactions: JTW
13,363
65,125
Your other option is purchase the Erickson setup with chocks. You will be drilling 12 holes per wheel to mount.
Or keep doing it as you are now.
I bought a set of the Erickson over the wheel chocks, I never installed them, Just couldn't bring myself to start drilling thru the floor of my trailer either.
nbomar
nbomar
4,416
17,854
Springdale, AR
CargoBuckle F18800 G3 Retractable Ratchet Tie-Down System, 2-Pack https://www.amazon.com/dp/B0030OGBCO/?tag=sxsweb24-20
Mine are about 8 years old. The plastic is cracking but the still are as smooth as butter for operation.
Reactions: Chooglin
TimG
TimG
OLD SKOOL
760
3,723
Southern Indiana
I bolted 3/8 D rings in front and behind each tire with steel backing under trailer wood
IMG 0133
IMG 0135
IMG 0137
floor to prevent pull thru. Got some 2 inch straps with locking snap hooks and ratchets with snap hooks from ebay all rated at 10,000 lb. went over the tires on all four and I will never haul it any other way again. I just towed it 3600 miles in one trip recently and never had to retighten my straps once. No wear and tear on straps,with protection sleeves on wear areas, nothing moves at all.On my small 10 ft trailer I run the front straps over and around the front pipe top as well to keep the sxs firmly pulled forward locked in place as well as down force on the front tires. The sxs rides on it's own suspension and the trailer's suspension making both tow better. There is 0 percent chance of this thing coming off my trailer. Me likey. Ratchet Straps
Buy the way you can get the 4 pack in the last picture very similar to what I use for $57.99 for all 4 and free shipping on ebay. Pretty hard to beat !
Chooglin
Reactions: TimG
I use 4 of these car hauling straps.
https://www.amazon.com/gp/product/B005C2AS1W/?tag=sxsweb24-20
I use one of each of these wrapped around the front bumper, and one wrapped around the rear ROPS mounting.
https://www.amazon.com/Vulcan-Classic-1-Ply-Flexible-Strap/dp/B01MTQE46T/?tag=sxsweb24-20
I will take a few pics this weekend of it loaded when I bring it home from camp. I have had zero issues with this setup.
If someone wants to use the straps he used in the video, I agree with @Farmer cut the damn things to length. why roll up 15' ever time you trailer!
I’ve looked at those full closure straps a time or two but just haven’t bought any yet..
13,363
65,125
use camelcamelcamel and set a notification for used ones.
All mine were bought used from Amazon, but were brand new our of the packaging. I don't think I paid more than $15 each.
Reactions: JTW
Koda
Koda
565
2,309
Canton Ga
IMG 1127
Been using the Erickson wheel chock setup for over a year now. Best method I've ever used. Just got back from a 3600 mile trip and never had any issues with straps loosening.
13,363
65,125
It is reassuring to see you guys aren't using dollar store ratchet straps. A few of the guys we ride with use the cheapest ones available. How they can put that much trust into them is beyond me.
Reactions: Chooglin
Shadesmn
Shadesmn
505
959
Ramsey, MN
I just did my aluma trailer this summer. Not gonna lie. It was painful at first to drill holes. But after a few it gets much easier. I just lined them up and measured out spacing between the ribs underneath. Used 8 bolts per 5ft piece of track, they arent going anywhere. Track is rigid as it is plus the load per bolt is all way more than the load of the machine against it. And as it's been said before, 2-3 min to load and tie down tops. I'm sure someone will say it needs more bolts, but the math doesn't lie, we've been running the same setup on another trailer that fits two machines for two seasons with no problems.
20180922 141106
Makes tieing other things down much better too since you have tiedown points about every 4”
RedFred1
RedFred1
301
619
North Carolina
I tied mine down like this today... worked fine. I just put new deck boards on the trailer and screwed down the track using tek screws. I only have two of the straps with the top strap... I may buy two more. The single strap works fine for the buggy but is too light for the tractor.
FredD
Reactions: Shadesmn
Farmer
Farmer
2,851
16,389
Southern MO
Great! I'll leave a day early to Canada next spring and swing by your place so that you can do mine! LOL.
But seriously.... I see the track appears to be painted, did you use stainless fasteners since steel and aluminum don't play nicely together?
Reactions: Shadesmn
Shadesmn
Shadesmn
505
959
Ramsey, MN
Come on by. Canada is just a handful of hours north from me. :D. And yes I did use stainless hardware and painted the track black to look a little prettier with the trailer. It was a weird greenish grey color that I didn't like so figured black would go well against the aluminum. Didn't take long to put them on with an extra set of hands, maybe 40 min which included pulling a couple short pieces off first that I did before I got the full length ones.
Farmer
Farmer
2,851
16,389
Southern MO
Good call on the stainless! I paint everything black. LOL
Reactions: Shadesmn
