P1000 Sun Visor / Air deflector
jenk61
jenk61
153
1,169
Southern Illinois
Thanks to the idea of air diverters that @mlynch001 made, I was inspired to make something similar. I had always wanted sun visors and thought maybe I could incorporate where I could have sun visors as well as the air diverters. My design skills are seriously lacking and the only program that I know how to use is Tinkercad. This is what I came up with. It allows you to use as a diverter or sun visor with infinite adjustments. I used washers printed from flexible filament so it holds in position. Didn't even have a need for lock nuts so far. I never realized how much air comes in between the roof and windshield until reading @mlynch001 post. At 20 mph it feels like a fan blowing on you. Instead of printing the diverter, I made a bracket and bolted it to a piece of 1/4" Hdpe, 9 inches tall and 12 inches wide.
PXL 20220802 155456065PORTRAIT
PXL 20220802 155502712PORTRAIT
PXL 20220802 155538144PORTRAIT
PXL 20220802 155658309MP
208,013
View attachment 346954View attachment 346955View attachment 346956View attachment 346957
Where did you get those brackets? I did this a couple years ago and used hinges made for boats deck lids to keep them open in the wind, worked great for a while and then failed. Still have them just been looking for different hinges. Thanks!
Reactions: Lady01 and JenElio
jenk61
jenk61
153
1,169
Southern Illinois
Still works for me. Sometimes loosens a little on rough ground. Probably need to make the tpu washers a little thicker or put some star washers on behind the knob.
bumperm
bumperm
1,850
6,651
Gardnerville, NV
Ram Mount, 1" ball, might work well for the brackets and would allow a broad range of adjustments. Also, I think using Plexi or Polycarbonate would be good as it doesn't block vision . . . unless, of course, you want to be able to use it for a sun visor. I have my tablet mounted up there, so I won't be experimenting with this.
Reactions: ChadD
