P700 Super cold won’t start
70Bones
70Bones
888
3,779
New Brunswick Canada
Done some looking at the 700 wiring diagram, there are 3 power supplies going to the dash display. 2 are present all the time, if the main fuse is good. The 3rd comes from the "main relay", one of the famous 4 relays. If it is damp and frozen, OR if the voltage is low it might not pull in, the effects of that would be no dash display, no fuel injection, no fuel pump, and no spark.
The engine will roll over when the voltage is too low to pull in relays.
I guess it's important when things like this don't work properly, to listen for the fuel pump. Makes it easier to troubleshoot. Also, if boosting the machine made things work, we might conclude that the battery voltage was just a bit too low.
212,780
Bites me some times, to over look the most obvious! It really aggravates me when I do that! HA!
RandyG
15
19
Not sure what it was. Went out in the morning and it started right up. And come to think of it @70Bones I don’t remember hearing the fuel pump, so I will def remember this in case it happens again thanks!
Russ989
Russ989
22,645
147,291
Sounds like some dielectric grease and protective coating may be needed.
Reactions: 70Bones
allgm1
allgm1
1,049
1,485
New Hampshire
I had the same problem with mine until I put a car sized battery and high octane fuel. My thought was the stock battery couldn't supply enough juice to turn the engine over and provide the ignition coil with ample power for a good spark. The car size battery has no problem cranking the engine and it will usually fire after a few seconds. The other thing I do when its really cold (actually do it all the time now) when I go to start it,I put the key in and turn it on and start with no delay. Some guys turn the key on and wait til the fuel pump stops before starting which is fine but it doesnt seem to help when its really cold outside.
jwfirebird
jwfirebird
927
1,446
western ny
if you are plowing it drains your battery more than it can recharge. you have to charge it with a charger after or it will always be low. it doesn't matter how big your battery is or if you have two your rectifier only puts out so much and if you are using more like a winch or stereo its going to be too low voltage if you don't charge it in the garage
allgm1
allgm1
1,049
1,485
New Hampshire
I have never put a charger on my battery. I plow with the tunes going, heater on if needed, but I always shut that stuff off before parking it and make sure the alternator had charged the battery. My pioneer runs at 14.4 volts when running and no accessories running so before I shut it off I always make sure it's charged back to 14.4.
jwfirebird
jwfirebird
927
1,446
western ny
to me it just seems easier to trickle it, that way probably works but you waste time and gas, the ctech charger I got wasent that much and you can charge anything and its waterproof. so I charge tractor and anything outside just drag a cord out, very easy
Russ989
Russ989
22,645
147,291
One thing is for sure, a hot battery is a must.
70Bones
70Bones
888
3,779
I think you're right Russ989, there have been so many issues reported lately that can be linked back to those relays, I think I'll put mine in the garage and see what it takes to move them, or at least di-electric grease them.
Reactions: Russ989
Russ989
Russ989
22,645
147,291
I may do the same.
xltman
xltman
188
369
US
I know on many fuel injectors you need a minimum amperage to have them work. If the battery is cold and not able to produce the amperage, the engine will turn over fine, but the injectors will never fire.
Sent from my phone while sitting with my feet up on night shift
Reactions: JTW and tjoreo
Roghubbard
Arizona
It cranks like normal, could it still be a battery prob? Sorry not real good with this stuff!! The dash not lighting up like normal is what really has me wondering
Frosted spark plugs? Maybe try running premium gas when it is so cold. When I bought my 700-4, the salesman recommended that I run 91 octane. And I live in Arizona!
ScottPhillips
I have a 2017 700-4. It is -33 with the wind chill here and the ol gir won’t start. Started last night and I plowed with it. But tonight when I put the key in the dash won’t even light up like normal. It cranks but won’t fire. It sits outside under a cover so could this be normal? Currently sitting in my 1 car garage with a heater pointed at it. But that’s the wife’s spot so can’t stay in there lol!!
I had the same temps and the same problem two weeks ago in Illinois. Is just hard on stuff in that cold of weather.
