P1000 SuperATV intimidator
Marine660
245
244
does anyone have input on the intimidator tires by superATV? I am thinking a set of the 28's would fit nicely without loft and should ride good.
Anyone have reviews or thoughts on this tire?
amc019
amc019
480
592
Little Rock, Ar
Great tire, had 32's on my RZR 1000. Would have gone with them again on this rig but wanted to try something different. They worked well under all conditions.
Reactions: Marine660
TOOLOUD
TOOLOUD
261
155
Benton,La
I have 30's on my pioneer 1k5D and really like them - they pull very good - climb out of ruts very good - clean out great.
nbomar
nbomar
4,416
17,855
Springdale, AR
I have the 28's on my 1000 and they rub slightly when compressed and turning (going through a ditch and turning). They seem to ride good and dig like crazy. Only have a couple hours on them so far.
chadbo
chadbo
Mama tried
2,044
5,659
Seminary , Ms
What do they run @ 10 psi on the 30 I wish the highlifter bracket would make them work but from what I'm reading that may not be an option
TOOLOUD
TOOLOUD
261
155
Benton,La
Will pull a measurement this evening when I get home. HL put 31's on a pioneer back in December but they had their bracket lift and forward arms too.
amc019
amc019
480
592
Little Rock, Ar
My 32" Intimidators ran small by almost an inch at 10psi.
chadbo
chadbo
Mama tried
2,044
5,659
Seminary , Ms
I seen where you posted that before that's what got me to asking because all this time I thought they ran true I guess now I'm hoping for small 30s or oversized 28so_O
Marine660
245
244
Will the bracket lift work with the 30s or do I need to look at catavos or similar lift height.
F
Fullthrottle
164
84
You need forward arched a arms to run 30s with either a bracket lift Or Catvos style lift.
Reactions: amc019
F
Fullthrottle
164
84
I just measured my 27x11x14 swamplites which are fine I just want bigger but they measured 26 inches tall by about 10 wide not sure what pressure is prob 12 psi.So outback max 28x10x14 which supposedly are 28.3 inches true will be perfect I think.
jguillot
jguillot
58
32
I picked up a set of Terms real cheap 29.5x10x14. Will spacers or offset wheels work? What width wheel should I consider? These are temporary until I add Portals then I'm running 31"s and larger wheels.
