Yes. That's exactly what I have on mine .will 235/75/r15 tires fit on a stock machine with aftermarket 15 5+2 wheels whats the height of those?
Mine are about 28.5 tall and yes they barley fit on stock machine. close but have had no problems did half to put one screw in inner fenders for full compression tuning .I it was different offset or had spacers it wouldn't workwill 235/75/r15 tires fit on a stock machine with aftermarket 15 5+2 wheels whats the height of those?
ThanksMan they look great, I like the style of the wheels too! Really feeling the upgraded front grille / bumper! I wish I had a tubing bender I need to design one... hmm.
Do you have wheel spacers looks wide, good looking rig.Mine are about 28.5 tall and yes they barley fit on stock machine. close but have had no problems did half to put one screw in inner fenders for full compression tuning .I it was different offset or had spacers it wouldn't work View attachment 102228View attachment 102229View attachment 102230View attachment 102231View attachment 102232View attachment 102233View attachment 102234View attachment 102235View attachment 102236
Only one inch in rearDo you have wheel spacers looks wide, good looking rig.
Same here. For my use they’re great. Plus got them at a decent price and they are hardly showing any wear after almost 1k miles.I got the maxxis mudder buckshot II. They have been excellent! View attachment 97914View attachment 97915
Mine are 15” post# 71. I run @12 psi. Rides much better. When I’m in sand, I’ll drop it to 8psi.@Cuoutsoors what pressure are you running your Buckshot Mudders II? And are yours for 15” rims?
Mine are for 15” rims and I’m running mine at 14 psi. Was running at 17 but was getting a harsher ride. At 14 psi ride is much better.
I installed SATV forward a arms and Highlifter lift with spacers front and rear.
9 psi in front 11 in rear little firmer than factory big horn but I do have beadlock@Cuoutsoors what pressure are you running your Buckshot Mudders II? And are yours for 15” rims?
I'd say you're right on. I've ran as low as 7psi and been fine. Anything close to 10 seems to be a good "set it and forget it" number.9 psi in front 11 in rear little firmer than factory big horn but I do have beadlock
