P1000 Switching to M/T Truck tires, from ITP Mayhem (pics)
BearWoods
BearWoods
92
260
East Stroudsburg, PA
That is a fair deal, the only place I see them cheaper right now is jegs.com but they have an estimated shipping date of 2/26/19 they might be on back order or out of stock at the moment. that ebay link is a fair price if they are in stock!
Reactions: BWAF
bucktaker
51
65
sw ohio/ETN
will 235/75/r15 tires fit on a stock machine with aftermarket 15 5+2 wheels whats the height of those?
Reactions: BWAF
BearWoods
BearWoods
92
260
235/75R15 is 0.9" taller, and 0.3" wider than the tires I had on previously, I do believe they will fit on a stock pioneer 1000 without a lift. They will slow the machine down a little bit, but that's to be expected.
on post #83 here: P1000 - Light Truck Tires???
You can see that size tire mounted on a stock height P1K 5 seater. They don't rub, but they look to me about as big as you wanna go without a lift.
The height of my Kumhos is 27" the ITP mud tires were 28", and the tires you are asking about are 28.9" tall.
Reactions: BWAF
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
Mine are about 28.5 tall and yes they barley fit on stock machine. close but have had no problems did half to put one screw in inner fenders for full compression tuning .I it was different offset or had spacers it wouldn't work 0555bfd90c76df4fe07c02870bbe67aa2ced8f0a71a0f4aa2d824abdc8e0da3c481cc60ffb7b9329b43795dcfd8cebcc559f2216feebf2e659c71143fbc8494546d57e0cfae2bf18ec2d6efdbc4649b72712390b69dc97f1f3cf5639baa150ef3cf15b901bd0e6d8e3ab76938c1badbe31f3139c13c5d9529ac06aa06093cd23331e4b8f81e84f1b8e85d14db437b64e
BearWoods
BearWoods
92
260
Man they look great, I like the style of the wheels too! Really feeling the upgraded front grille / bumper! I wish I had a tubing bender I need to design one... hmm.
Reactions: BWAF
BWAF
BWAF
8,857
42,437
Carthage MO
Thanks
perry
perry
191
168
South Dakota
Mine are about 28.5 tall and yes they barley fit on stock machine. close but have had no problems did half to put one screw in inner fenders for full compression tuning .I it was different offset or had spacers it wouldn't work View attachment 102228View attachment 102229View attachment 102230View attachment 102231View attachment 102232View attachment 102233View attachment 102234View attachment 102235View attachment 102236
Do you have wheel spacers looks wide, good looking rig.
Reactions: BWAF
106,526
These are my LT MT tires there 30x9.5x15. I have SATV forward arched arms. Clearance so far is not a problem. I think what @BWAF has in size should work on a stock machine. If you want total clearance, some spacers and fox shocks or stock shock bushings would definitely help. The spacers and bushings are an easy cheep upgrade.
EC32F76C A4D1 4E0F B6B1 59CDD290C486
332276B1 D29B 405A BFF9 8ADDA31E2AB6
Reno58
Reno58
74
Middle TN
@Cuoutsoors what pressure are you running your Buckshot Mudders II? And are yours for 15” rims?
Mine are for 15” rims and I’m running mine at 14 psi. Was running at 17 but was getting a harsher ride. At 14 psi ride is much better.
Upload 2019 1 13 13 32 43
I installed SATV forward a arms and Highlifter lift with spacers front and rear.
Reno58
Reno58
74
Middle TN
Sorry, that was meant for @Cuoutdoors. I have fat finger issues today.
Reactions: BWAF
BearWoods
BearWoods
92
260
@Bones the A/T tires are good for states that the machines are street legal, but the lack of spacing between the tread blocks means they will clog up the moment they get into any sort of mud.
Just my personal opinion, but I chose M/T tires and not A/T tires because these machines are really meant to spend most of their time off the pavement. I suspect a lot of the users on this forum may even find that truck rated M/T tires aren't aggressive enough for their usage. The level of traction in deep mud or sand that even a light duty M/T offers, can't be had with an A/T tire. For those lighter duty users who ride trails, farm fields, back yards, and woodlands.. an M/T tire tread design fits the bill almost perfectly.
I like to refer to A/T tires are jack of all trades, master of none. You can be OK at everything, but can't be great at any 1 thing if you are all purpose. If you are specialized like M/T you can be much more useful when the ground gets soft, and the hills get steeper, even though you still traverse pavement quite well.
Reactions: BWAF and Remington
106,526
Mine are 15” post# 71. I run @12 psi. Rides much better. When I’m in sand, I’ll drop it to 8psi.
@BearWoods, my Achilles DH MT’s lugs are spaced and height it about the same as my Motoclaws were, just not as hard a tire. I haven’t had them in the muck yet but with that comparison..I’m going to assume and hope that they will preform and grip alike in most situations. When I chose the LT tire, I was looking for a similar pattern. Your right,with an AT tire folks won’t be happy when on trail and muck, there lugs will not spit out mud and will cake on.
Reactions: BWAF and BearWoods
BWAF
BWAF
8,857
42,437
Carthage MO
9 psi in front 11 in rear little firmer than factory big horn but I do have beadlock
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Yes my rims are 15". I have been running about 10psi. That gives a little flex in the sidewall and seems to grip really well. I air up more if I'm in a really rough area I'm concerned about pinch flats.
With the snow plow on and 200lbs in the bed I aired up to 15psi.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I'd say you're right on. I've ran as low as 7psi and been fine. Anything close to 10 seems to be a good "set it and forget it" number.
Bones
199
203
Bourbon Mo.
Anyone have an opinion about these? Maxxis Ceros UTV Tire 29x9R-14? Will they clear on a stock machine? Other than being high they look like a tire that would fit my needs.
Reactions: BWAF
