Tablet mount
116,574
I originally picked one of these up, had one in my POO POO and loved it, but it won't fit with the super atv flip up windshield.
Fixed it for ya!😉
Cache Valley Duo
Richmond, UT
I mounted mine on the oh s*** bar with several RAM components. I can reach it from the driver's seat and it's not intrusive should there be a passenger. Have this set-up in all 3 Talons and getting ready to install in my Pioneer
I have done the same. I bought a tablet mount on Amazon with a 4 bolt mount (metal, not plastic). I drilled 5/32" holes through the left side of the passenger handlebar. I was only able to fit three of the 4 bolt holes given the size of the bar but mounted my 10" tablet on it last week and it was completely stable during a four hour rock filled ride. The location is just above the handhold and close enough for me to reach from the driver's seat while low enough to not block any forward sight lines.
Reactions: CID
Cache Valley Duo
Richmond, UT
my solution above cost $25 (including my two broken drill bits) and an hour of time.
Jason W
Jason W
The Ginger Cracker
1,295
10,886
Western NC mtns, Marion
  1. Talon X LV
Lots of very small screws for assembly, so far very happy with the ram mount
Great qaulity
20241026 150950
20241026 150938
20241026 150932
deltajp
11
22
Huntington Beach, CA
I used about $0.25 worth of velcro and put it right where Honda should have put the gauge panel. Since the gauge panel is basically worthless anyway, the tablet is in a great spot. I run Backcountry Navigator Pro side-by-side with Bicycle Speedometer on an Android tablet. Made a little visor out of a bendable thermoplastic sheet.
PXL 20241113 230542820
PXL 20241113 230648134
Reactions: CID and -Bear-
-Bear-
-Bear-
NTCTAP Master Fabricator
10,329
108,195
Black Hills, SD
www.facebook.com
  2. Talon X LV
I started off with the fold down tablet holder off Amazon. Been using it for a while and I like it but I decided to switch over to a Ram Mount this past week and I like the look better than my previous. The new Ram Mount is made specifically to be a docking station for my Samsung Galaxy Active Tab 5.
Before
Tablet Mount
After
Tablet Mount 1
Tablet Mount 2
Doogle
Doogle
216
312
Surprise,Az Cincinnati,OH
I need a larger screen to see where I'm going. I have an 11" tablet. I cut up an 1/8" piece of aluminum and put it where the safety warning crap eye sore used to be. Under the plastic (after removing the glove box) I attached the 1 1/2" Ram mount. The 4 screws through the Ram base, 1/8" aluminum, and plastic are threaded into a 3"x3" plate for a little more stability. Without added support I believe the plastic would fatigue and break off after bouncing around on trails. I haven't had it on the trails yet. I'm preparing for the AZPT in March. I have the 6" Ram arm on it now. I've ordered a 3.5" arm. 6" arm plus the size of the tablet, I think would be too much torque for the setup. On trails I usually take my 1/2 windshield off and store in a sleeve over my TSC trunk. I value seeing the trail more than wind protection. I'm researching how to stiffen the windshield so when I'm on the road, it doesn't flex into my throat and front/rear camera monitor.
Shield 2
