aprils_fool
I had the S & B filter on the original T1KxLV and will be placing it on the new 2.0 version in similar placement to PaulF. The only sound I heard from it was the fan running before starting the machine after that...nothing.
Before I purchased it I called S & B and questioned them about mounting it up close behind the rear window and below the roof line so it wouldn't be in harms way and was told it only needed to be spaced a couple inches from the window and did not need to be in direct air flow to work properly.
As far as needing to see it........ if you look at the picture @PaulF posted of his very nice looking ride you can clearly see that you will know when the water is getting too close to your intake cus you'll already be holding your breath.
The S & B filter is sold as a Honda Accessory so that makes it a factory approved snorkel my eyes
