Talon Talon X on 31's
clynwoodg
10
19
Got my new Wheels and Tires on today.
Raceline Ryno Beadlock 15x7 +10
EFX Motoclaw 31x10x15
TalonX3 2
TalonX1 3
906UP
906UP
12,970
120,809
da Yoop
Looks good, do you notice any power loss with the bigger rubber?
Reactions: Isaiah and Russ989
Russ989
Russ989
22,557
146,443
Looking good!
Reactions: Isaiah
stellarpod
stellarpod
821
3,024
OKC, OK - USA
If you don't mind sharing, where did you buy? And what was the approximate delivered cost?
Thanks,
Steve
Reactions: Isaiah
clynwoodg
10
19
No rubbing whatsoever. Haven't noticed a loss in power either.
The tires measure out to 30 1/8" at 15 psi.So not quite a full 31.
I also used 1 1/2" spacers in the rear to even out the width. I am at 68" both front and rear.
Cobweb
Cobweb
67
172
Hexi Hollow
This setup looks awesome on you rig. How do the tires ride on pavement? I have read that they are not well balanced and jump a lot.
Thanks!
Reactions: GPR1500SC
ThunderChicken
ThunderChicken
69
145
BATH
I see your using spacers in the rear. what off set are you running
Reactions: Isaiah
clynwoodg
10
19
These tires are not the best on pavement, but they don't jump or anything. Was a tough decision between these and the Motovators. They would have done better on pavement probably.
Offset is +10.
Reactions: Isaiah and Cobweb
Cobweb
Cobweb
67
172
Hexi Hollow
Offset is +10.
Thanks for the reply. Sorry to dig deeper, but what didn't you like about them on pavement?
Reactions: Isaiah
clynwoodg
10
19
They are great off road, which is what they are intended for. If i was more on the pavement i would have gotten a more pavement friendly tire. It isn't that they are bad on pavement. Just aren't the smoothest.
Reactions: Isaiah
