Talon1000x4 rear wheels crooked
W
Willt1977
25
34
Kettering ohio
  1. Talon X4 LV
I have a 2020 talon1000x4 and recently noticed that the back wheels were kicked out in the front. Have heard it is possibly a blown shock. Anyone have this issue
W
Willt1977
25
34
Kettering ohio
  1. Talon X4 LV
Screenshot 20220104 163859 Gallery
PaulF
PaulF
1,462
4,814
Pics can't really show what is going on due to optical illusions. For instance, to me it also looks like there is a lot of negative camber too.
Portals will add extra leverage and lower the suspension geometry so you may need to adjust your ride height so the suspension is back to stock geometry. The formula is...
New Ride Height = Stock Ride Height + Portal Size + (New Tire Diameter - 28")/2
After you make sure you are at the correct "new" ride height, What are the actual Camber and Toe readings on the rear?
208,726
After you make sure you are at the correct "new" ride height, What are the actual Camber and Toe readings on the rear? rid
What if he doesn't remember his original ride height, I got got a trick for setting spring sag from motorcycle racing years.
Reactions: JenElio and Isaiah
PaulF
PaulF
1,462
4,814
Can't really forget the factory ride height, it is all over the internet. Honda calls it "Ground Clearance" (circled on is the 2020 X4LV)...
1641343923465
Hometeam
Hometeam
980
4,039
Normal, IL
That's what I was thinking. It's definitely out-of whack
On my cousin's it was really hard to see the bend in the rear arm by just standing looking at it and it wasn't much of a bend to put it out of whack. He slid back down a tall rock face and slammed his back wheel just right tweeking it just enough. It was a really hard hit!
W
Willt1977
25
34
Kettering ohio
  1. Talon X4 LV
Definitely looked it over good. No paint chips or obvious bends. It was like that before I installed portals. I was hoping once I changed out all the s*** u gotta change to put on portals it would fix it but it didn't. So I'm guessing it has to be bent trailing or radius arms.
208,726
How did he fix it?
Reactions: Isaiah and JenElio
Sheetmetalfab
Sheetmetalfab
2,172
13,598
Alaska
Yeah you have bent trailing arm.
mine with portals is straight.
Hometeam
Hometeam
980
4,039
Normal, IL
He bought a new factory arm and swapped it out. Easy job overall. That was over a year ago so I don't remember the cost of the arm. He didn't have any paint chips either at the time. Could definitely tell a difference wirh it out of the machine next to the new one.
