The good old Cummins days!
319,528
Jakes on big engines are electrical and control the valves, exhaust brakes close off the exhaust flow.
I agree but they have same basic results, and both create drag. One is pressure build up against the piston and one is vacuum.
Reactions: Mopower58
Mopower58
Mopower58
CST is the Best!
69,704
640,962
Crystal Springs,Ms.
IMG 2335
319,528
This is the daughters truck of a local Cummins performance shop owner I know. It’s a badass truck, don’t exactly want to pull up to it thinking you’re hot s*** in nearly anything.
AAD07058 3858 4CB0 BC29 A7693A717C87
319,528
Ya I’ve seen that for the Cummins, not too surprising being a heavy equipment engine. Bad ass that Cummins himself was the original designer, I wasn’t aware of that, figures though.
I had thought of doing just exhaust brake on my ‘98 but now running the ‘93 there’s just no need with the manual.
Mopower58
Mopower58
CST is the Best!
69,704
640,962
Crystal Springs,Ms.
When I had the 07 and the 2012 I used the exhaust brake a lot.Especially when pulling the gooseneck.
Reactions: CumminsPusher
319,528
I swear I’d do the engine brake if I had common rail, it’d be funny hearing that after f***er after my buddy comes into camp with his PowerStroke turbo screaming at 5mph!
Mopower58
Mopower58
CST is the Best!
69,704
640,962
Crystal Springs,Ms.
Not sure how long the Turbo will last but our closest neighbor has a 2003 Cummins 4x4. He has to go fairly slow down the driveway, about 1/2 mile. But when he gets home he makes sure he revs it up 2 or 3 times then immediately cuts it off. Of course he has a straight pipe on it.
319,528
Lol! Ya make sure that fan is spinning at full R’s before you kill it. They just love 150k rpm with no oil pressure:eek: f***ing retards. Lucky turbos have gotten cheap I guess
Mopower58
Mopower58
CST is the Best!
69,704
640,962
Crystal Springs,Ms.
Lol! Ya make sure that fan is spinning at full R’s before you kill it. They just love 150k with no oil pressure:eek: f***ing retards. Lucky turbos have gotten cheap I guess
The only good thing with the long driveway is that it has time to cool off.
319,528
