Posted for those who are obsessed with curiosity about the inner workings of things they have no business getting into:
Early neutral switches had some problems. When it fails, it usually results in throwing a 5 - 2 code and going into 1st gear "limp home" mode (from what I understand. My '21 P1000-5 SE did that recently. I removed the neutral switch and tested it the wrong way, thinking the exterior wire lead contact (left end of "A") would short to the body "G" when the button (right end of "E") was pushed. This is not how it works. The part is more a spring loaded connector than it is a switch. Part "A's" body is an insulator, as it part "F". "B" is an oil seal, "C" is a sliding contact that slides on the left side of pin "E" and maintains contact through when the right side of pin "E" is pushed by the actuator (inside motor). At no time do the "switch" internal parts make or break, though if there was a fault in this part, the most likely failure would be an intermittent contact between the wiper "C" and the pin shaft "E".
I took it apart carefully, using a parting tool on the lathe, figuring I might put it back together if I fixed it. I think there may have been nothing wrong with it and I may still have a problem elsewhere &^%$!
