P1000m5 The Robo Build
Robobrainiac
Robobrainiac
2,459
8,563
Robobrainiac
Robobrainiac
2,459
8,563
What's In The Boxes As Of: 12-01-20
As of right now in boxes that I need to install are the following...
Honda OE Fabric Top Door
Honda OE Fabric Mid Panel
Denali Pro Snow Plow
High Lifter Front Arched Forward Arms
High Lifter Arched Rear Arms
PBR Switch Panel
HondaSXS Store Fan Bypass Harness
HondaSXS Store Key On Harness
HondaSXS Store Seat Belt Bypass
HondaSXS Store Reverse Light Harness
Vision Bolt Beadlock Wheels
SuperATV Intimidator 28" Tires
I will edit this list by underlining the parts as they are installed.
Russ989
Russ989
22,581
146,663
What's In The Boxes: 12-1-20
Honda OE fabric top door
Honda OE mid panel
SuperATV Intimidator 28" tires
Just the beginning, it never ends! Lol
Robobrainiac
Robobrainiac
2,459
8,563
Current Future Mods On The List:
OTRATTW Switches
LED Pod Lights Front/Rear/Side
Dual Battery Setup - Installed Post # 63
Turn Signal Kit
Front/Rear Bumper
MB Quart Overhead Stereo - Installed Swamp Donkey With Rockford Sub and Rockville Amp : Post # 61
Elka Stage 3 Shocks - Installed Fox Shocks : Post # 86
Robobrainiac
Robobrainiac
2,459
8,563
Ready, Set, Snow: 12-10-20
I installed the Denali Pro Snow Blade Today. It was 71F :/ the blade seems nice and sturdy. I had an issue with the mounting bracket that locks the angle of the blade. One of the brackets does not line up. It is number 6 in the diagram. I will include some pictures of it installed and removed from the mount. HondaSXS took care of me tho and shipped out new brackets 👍 I purchased some pull pins from tractor supply for the blade sliders. I wanted to be able to adjust the height as needed. I plan on going from gravel drives to asphalt/concrete drives. I have never used a plow before so I just assumed it may need adjusting so I used pull pins instead of the included cotter pins. I am excited to use it and it looks great.
IMG 20201210 190549 IMG 20201210 200123 IMG 20201210 200237 IMG 20201210 140020 IMG 20201210 142208 IMG 20201210 142315
HondaSXS took care of me. I had new brackets in just a couple days and I have them installed and the plow is ready for work!
Reactions: toddvdh and Mudwing
Coeus
Coeus
Major General
59,022
590,423
Signal Mountain, TN
  2. Talon R4 LV
OTRATTW Switches
Dual Battery Setup
Turn Signal Kit
Front/Rear Bumper
Elka Stage 3 Shocks
Where are you going to put the Pod lights?
Robobrainiac
Robobrainiac
2,459
8,563
The Arch: 12-15-20
I installed the front high lifter forward arched control arms today. The only odd thing I noticed was the factory right front upper ball joint seemed like the thread ends were messed up. I had to fight it to get the nut off. Otherwise everything went smooth. It looks good. I plan on doing the rear control arms Thursday.
IMG 20201215 174310 IMG 20201215 185714 IMG 20201215 185710 IMG 20201215 185706
I got the rear arms installed and did an alignment. They look really good. I put the camber bolts in backwards at first and had to redo them. Other than that it went smooth. IMG 20201217 140946 IMG 20201217 140949 IMG 20201217 140952
tdhanses
tdhanses
1,044
3,553
Kansas
The upper ball joint threads are made from a super soft metal, I jacked mine up tapping them out with a nut on them.
Reactions: Robobrainiac
Robobrainiac
Robobrainiac
2,459
8,563
Those threads in the picture were from the nut just being taken off. I am happy for my high lifter parts.
Robobrainiac
Robobrainiac
2,459
8,563
New Shoes: 12-17-20
Throughout the week I have been working on what I wanted to do with my wheels. I went with a 14"x7" 5+2 Vision Bolt 544BL Beadlock Wheel. I thought it would look cool with the rings painted orange. I was going to have them powder coated but I spray painted them instead. They turned out really good. I chose spray paint because I realized that it is easier to redo when they get scratched or beat up. I used Westlakes paint. I have had good luck with their paint in the past. I buffed up the rings with some 3M scotch brite and then cleaned them up and painted them. I mounted some 28" SuperATV Intimidator Tires and it turned out really good.
IMG 20201208 114708 IMG 20201208 114722 IMG 20201208 192148 IMG 20201209 072343 IMG 20201209 074826 IMG 20201217 165609 IMG 20201217 165616 IMG 20201208 192159 Screenshot 20230219 204827 Chrome
Russ989
Russ989
22,581
146,663
New Shoes: 12-17-20
Throughout the week I have been working on what I wanted to do with my wheels. I went with a 14"x7" 5+2 Vision Bolt Beadlock Wheel. I thought it would look cool with the rings painted orange. I was going to have them powder coated but I spray painted them instead. They turned out really good. I chose spray paint because I realized that it is easier to redo when they get scratched or beat up. I used Westlakes paint. I have had good luck with their paint in the past. I buffed up the rings with some 3M scotch brite and then cleaned them up and painted them. I mounted some 28" SuperATV Intimidator Tires and it turned out really good.
View attachment 241796 View attachment 241797 View attachment 241798 View attachment 241800 View attachment 241801 View attachment 241802 View attachment 241804 View attachment 241805
That looks really good, well done.
Robobrainiac
Robobrainiac
2,459
8,563
A Little More Volume: 04-14-21
Purchased the 2nd Aomais Go Speaker so I can stereo sync 2 together and get some more volume. They seem really nice, loud, and clear. It didn't take much to install them. I am currently using some bungee balls wrapped around the ROPs. I think I will get some roof clamps and mount them to the speakers some how to make an easier mounting system. I don't think you can find a better system for $125. That's just my opinion. They are also very well waterproof as I found when I dropped the first one into lake Michigan. It floats and I grabbed it and it still works great.
IMG 20210414 195554
Robobrainiac
Robobrainiac
2,459
8,563
An Example: 06-17-21
Just to show how my projects all go. At the bottom of this pile is my high lifter lift. I have had it since May 4th. On top of the pile is some light bulbs for the truck, a transmission for a trailblazer 250, a chain for the 300ex, and the newly painted beadlock for the pioneer spare. So many projects and not enough time.
IMG 20210618 080624
Reactions: toddvdh and Isaiah
Robobrainiac
Robobrainiac
2,459
8,563
Time For Some Catching Up: 07-09-21
I did a few projects thru the month of July. I added the high lifter logo that came with my control arms to the rear of the roof. I put some orange paint under it to keep up with the nice theme.
I added 2 bungee style cargo nets to the rear top of the rig above the seats. I used a small hole net that is black and then a second larger hole net in orange. I used the provided clips in the packaging to wrap around the various edges of the ROPS.
I added some Kolpin mounts to the upper rear ROPS. I used hose clamps to attach them to the ROPS. I use these mounts to hold a shovel that I got from Menards.
I used the space on the driver side upper ROPS area to mount an axe as well. It fits solid and tight. I drilled a hole on the rear plate section where a pin is passed thru securing the axe in place.
I mounted a hi lift jack onto the ROPS overhead towards the rear. I used some jeep bar mounts.
I got the spare tire mounted and beadlock painted.
Lastly I purchased the vinyl decal stickers in orange. I have only done the front and have not done the rear yet. I was a little disappointed in the fitment. They don't seem to be accurately cut and it would have been super nice if the seller had used transparent transfer tape.
So far everything seems to be working out well.
IMG 20210716 190433 IMG 20210716 190439 IMG 20210716 190445 IMG 20210716 190513 IMG 20210716 190649 IMG 20210716 190659 IMG 20210716 190707 IMG 20210716 193000 IMG 20210709 123357 IMG 20210709 123425 IMG 20210709 134446 IMG 20210709 181357 IMG 20210709 181602
Reactions: toddvdh and Lady01
Robobrainiac
Robobrainiac
2,459
8,563
Let There Be Light: 07-16-21
I installed some LED fog lights on the ROPS on the rear facing the sides. I used hose clamps to mount them in place. I have not wired them up yet however testing has shown they are nice and bright.
I replaced my DIY LED whips with some store bought versions. I have plans on doing a signal kit, and trailer wiring at some point. I really wanted the whip control box to be integrated into the lighting system. I wasn't able to find much info on making my own system like this so purchasing it was the easiest thing. I used a couple of the bar mounts per side to mount the whips. I used a sticky wheel weight meant for balancing to space it and everything is solid. It slightly hits the bed when dumping but the only time the bed is up for me is engine maintenance so it doesn't bother me.
IMG 20210720 175239 IMG 20210720 175247 IMG 20210720 175608 IMG 20210708 200912
