Ran across this article that came out today, had read similar before but was too busy to post. How does this grab you for a sport SXS.
1000CC / 112 HP Naturally Aspirated / 5 Speed auto Clutch gearbox w/ Paddle Shifters / 17" Suspension Travel w/ fully adjustable FOX RC 2.5 Shocks / 78 MPH Top Speed / 13" Ground clearance / FACTORY Accessory 70% 1st Gear Reduction kit for crawling. Machine auto shifts to 1st on stop, Launch control - pull back both paddles rev to 10,500 RPM let go to dump clutch.
All-New Yamaha Sport Shift 5-Speed Sequential Shift Transmission
Yamaha breaks new ground with Yamaha Sport Shift, a sequential 5-speed manual transmission featuring Yamaha Chip Controlled Shift (YCC-S) technology. This system combines the power, durability and efficiency of a traditional manual transmission with an advanced automatic clutch system that replaces the foot-operated clutch pedal with sporty paddle shifters mounted to the steering column. Plus, a Launch System provides for thrilling take-offs.
Do I have you attention yet? How about you HONDA? Release the beast in hiding to answer this machine!
Specifications, Pictures and Article below
Model: 2017 Yamaha YXZ1000SS SE
Engine Type: 998cc liquid-cooled DOHC inline three-cylinder; 12 valves
Bore x Stroke: 80.0mm x 66.2mm
Horsepower: 112 HP
Compression Ratio: 11.3:1
Fuel Delivery: Yamaha Fuel Injection (YFI); three 41mm Mikuni® throttle bodies
Ignition: TCI: Transistor Controlled Ignition
Top Speed: 78 MPH
Transmission: Sport Shift, paddle shift with auto clutch; 5-speed sequential with reverse
Final Drive: On-Command; 3-way locking differential; selectable 2WD and 4WD with diff lock; shaft drive
Suspension / Front: Independent double wishbone w/anti-sway bar, fully adjustable FOX® 2.5 Podium® X2 Shocks; 16.2-in travel
Suspension / Rear: Independent double wishbone w/anti-sway bar, fully adjustable FOX® 2.5 Podium® X2 Shocks ; 17.0-in travel
Brakes / Front: Dual hydraulic disc
Brakes / Rear: Dual hydraulic disc
Tires / Front: 27 x 9.00R-14 Maxxis® MU09
Tires / Rear: 27 x 11.00R-14 Maxxis® MU10
Dimensions L x W x H: 122.8 in x 64.0 in x 72.2 in
Wheelbase: 90.5 in
Turning Radius: 236.2 in
Ground Clearance: 12.9 in
Fuel Capacity: 9.0 gal
Wet Weight: 1554 lbs.
Bed Capacity: 300 lbs.
MSRP: $23,399 SE version as shown
Horsepower: 112 HP
Top Speed: 78 MPH
Wheelbase: 90.5 in
