P1000 Thinking I've got a lemon...
John_S
59
114
Tennessee
This is going to piggy back on several other threads I am currently seeing. As I posted before I had an issue with my 2018P1000/3 LE (~50hours) which took 2 weeks at the dealer and a new ECM to correct. When i got it back it was running, but this past weekend while spraying my fenceline the machine quit while idling and I could not get it restarted. After a walk back to the barn I toed it back with my tractor. I was able to restart it the following morning, but the same issue as others are having, rough idling, clunks while placing in gear, lurching and stalling. This is not what I expected from a Honda. I'm wondering if I could/should withhold payment on this until it is sorted out. Very disappointing to see so may others having similar issues,
BWAF
BWAF
I get paid to pass gas
8,864
42,477
Carthage MO
Drained battery to much with sprayer or bad frame ground back by engine check all connections and charge battery these do not like low voltage add 2nd battery
John_S
59
114
Tennessee
Are the charging systems that weak on these machines that it cannot support a 12 volt sprayer while running? I'll check battery voltage (do not have a load tester) and recharge, then see how it does.
Reactions: BWAF and Biteme
Neohio
Neohio
Beast of the East
17,720
85,397
Painesville Ohio
It isn't the charging system as much as a sensitive transmission. When voltage drops, the transmission does weird things.
BWAF
BWAF
8,864
42,477
Carthage MO
No but if you had bad connections it wasn't charging right
Reactions: Biteme
