P1000 Those with knowledge...
500
500
589
932
I have very slight play in my hub/bearings.
2018, 70 miles.
What is allowable tolerance?
Neohio
Neohio
Beast of the East
14,588
73,846
Painesville Ohio
I don’t see a spec for wheel bearings.
Reactions: JTW
ToddACimer
ToddACimer
Pioneer 1005-2
3,678
15,560
Oshkosh, Wi
What does very slight mean? Any chance they got water in them and wiped out all the grease? Is the o-ring on the CV shaft?
Reactions: JTW
I don’t think you should have any at 70 miles on an 18.... are you sure it’s in the hub?
2018, 70 miles.
Front or rear wheels?
The rear knuckles have plastic bushings that I’ve already had to replace. The bearings shouldn’t have play in them at your mileage, heck I’ve only got 2500 more miles and mine are tight.
Make sure the hub nut is tight?
Is the play a loose tie rod? Loose rack and pinion gear mesh? Loose a-arm bolts? Maybe it’s the upper or lower ball joints?
Reactions: JTW
500
500
589
932
I noticed because I installed arched front arms and noticed during final checkdown of all bolts, etc.
Play is hub/bearings. Bushings are all new and tight. Tie rod end tight. Ball joints new and tight. All verified. To confirm it was the hub or bearings, first I always check side to side movement in the tire to feel for tie rod end, rack, etc. No play there. Next, I placed my pinky between the outer axle cup and the knuckle where the axle goes into the knuckle while someone else grabbed the top and bottom of the tire and pulled back and forth. When the tire is moved top to bottom, I can feel the cup pinch my finger against the knuckle slightly. This ruled out ball joints, etc. as the entire knuckle would move if it were that, not just the axle cup.
Drivers side tight at 110 lbs. Passenger side I have retorqued twice, and it reduced the play to almost being non-existent, but it's still there. Then, my concern became over-torquing. @JTW
Alas, the question of should there be any tolerance at all?
Sounds like the answer is no... Makes me wander what's up? Bearings were like new when I had everything apart.
@ToddACimer , regarding the axle o-ring, neither axle had an o ring on them. Axle nut threads, shoulder, splined back to 90 degree shoulder where it looks like the hub would seat, then convex shoulder where the bearing shoulder would seat. Definitely no o-ring on either axle as I always clean off the factory grease and re-grease before reinstalling hub onto axle splines.
I am OCD about my stuff, everything gets put out on shop cloths, cleaned, regreased (i.e. axle splines, inside hub).... Both bearings were full of grease from the factory also, and the retaining ring on the outboard side of the hub was covered in grease as well on both sides when I pulled everything apart.
Wander if they got rid of the o-ring for 2018 like they did the lower ball joint circlip per the parts fisce.
pct
pct
Lost in the hills
790
1,023
Letart WV
I have had several different brands of SxSs over the years and all of them had some play in the wheel bearings
Reactions: 500
elkaholic
elkaholic
Illegitimi non carborundum
2,097
8,606
Ridgeway, SC
@500, did you disassemble the axles and hubs when you put in the arched arms? I did not. I merely separated the steering knuckles from the arms while leaving steering, brakes, and axles attached.
500
500
589
932
O ya. Thor hammer couldn't separate the knuckle from the ball joint. Had no choice. Had to beat them out with a nut on the stud with a 10lb BFH to free them. Needless to say I bought new ball joints.
Reactions: joeymt33
elkaholic
elkaholic
2,097
8,606
Ridgeway, SC
I bought new ball joints to start with. Mine were tight but I have had much more difficult ones than the P1K.
A few love taps with a 5 pound hammer on the knuckle near the ball joints and they popped free.
500
500
589
932
Not these...
They didn't speak the love language.
Reactions: JTW and ohanacreek
