P1000 Thoughts on what battery to use for auxiliary battery.
Ericseabaugh
Ericseabaugh
274
2,256
South Central Illinois
I have a question that I know you folks can give advice on. I am due to replace my factory battery in my 2016 1k5. I am going to do the dual battery setup and wondering what battery I should use for auxiliary battery without breaking the bank.
Dirtstiffs-1000
Dirtstiffs-1000
1,657
6,034
hondasxs.com
My auxiliary battery
Battery image GYZ32HLx21184
Ericseabaugh
Ericseabaugh
274
2,256
I appreciate the info fellas. Think I will give the mighty max a try. The price is definitely right.
Wisco pioneer
Wisco pioneer
41
203
With the aux battery set up will the alternator charge both batteries?
bumperm
bumperm
1,899
6,778
Gardnerville, NV
Yes. Many here use a True battery isolator . . . it's really a management system. It will allow a charging source for either battery to also charge the other battery once the battery being charged reaches 13.3 volts or so. When discharging one battery, it will allow the other battery to "help out" but will not allow the battery helping to drop below 12.8 volts.
As an example, if you are winching with engine off, as circumstance won't allow you to run engine, the aux battery (usually primary for the winch) will run the winch but the main battery will help out until it's voltage drops to 12.8. Thus reserving power to start the engine later.
Disclaimer, I'm getting old, so stated voltages may not be exact, but you get the idea.
Wisco pioneer
Wisco pioneer
41
203
That's what I thought, putting plow on and just making sure. Thanks
mactoyscb
38
147
canada
I have been running the True isolator and a mighty max battery as aux with no issues at all. Can't go wrong for that price it seems. Good luck! So much great info to be found here.
StewB
StewB
723
3,366
Bumperm's been the source and fountain of all things voltage. Hear him, or die.
(allrighty then, there's no no need for anyone to die or even get close. Don't be stupid and cellphones can help.)
208,726
I called Tru Battery Isolators and asked the what battery I needed, they told me the Odyssey, that was five years ago, still going strong?
Reactions: Ericseabaugh
