P1000m5 Tie down pics!
Bigred48
Bigred48
49
39
Peoria Arizona
Been looking for Pioneer owners to post pics on how they tie down there machines to their trailers. Mine seem to come loose at times. thanks yall!!!
Reactions: sharp
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
UTV (Side by Side) Tie Down Pack With chain extension. About the best straps you can get and universal for strapping other things. Only takes a couple minute to put 4 straps on and will not come disconnected. Pretty sure there is already some long post on this subject.
The link Snuff posted is where you need to start... and then buy some of these.
CC2C1F2A C0D6 43D9 B57A 8391605B8FD8
https://www.amazon.com/gp/aw/d/B01GIMUDEQ?tag=sxsweb24-20
Reactions: sharp
IMO, the etrack system is the simplest, cleanest and least expensive with snap hooks that won’t fall off....
TimG
TimG
OLD SKOOL
795
4,006
Southern Indiana
Put you some heavy D rings on your trailer floor in front of and behind each tire and use the ratchet straps with snap hooks like JTW posted above and that puppy won't budge. The tires giving some keep the straps from loosening as well.
BC5A6FA2 BFB3 4A99 ADF9 857E2A97A2E3
Over the tire to e-track that is welded or bolted down, threaded with washer and nut, not a lag bolt.
Trailer rides better, EASY to tie down in under 5min, less if you leave the tie downs on the trailer deck while you ride.
I fought going this way for the longest time but it works really well.
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
That's a nice set up posted above using wheel bonnets….
Hondoman
Hondoman
727
1,697
Texas
No lift or rubbing right.
Hilifter lift 2.5". No rubbing before or after lift. I have 1" spacers on the back to even the track front to rear. Wheels are 5+2 offset and the tires sling mud bad as you can see in the pic. I've since added mudbusters but yet to try them out.
Reactions: Bigred48
MikeG
MikeG
359
2,478
Baton Rouge LA.
The only thing I don’t like about this is the fact that you have nothing keeping the strap from sliding off the side. I would use a actual tire strap.
