tilt engine cut off
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
ok i was watching some of the old pioneer takeover videos and then with my recent roll. i cranked it back up at around 50 degrees. but i also ran at about 60degrees in another spot with my roll bar on the ground in a ditch. is there a yr they put the cut off in or does anyone know what angle they are set at?
43,590
I believe the consensus was that the 700...the 2014 model at least, doesn't have a tilt kill.
I believe someone who had rolled onto the side on FB or one of the forums confirmed that the engine kept running until he shut it off. There is also nothing in the service manual about it.
Don't know about the 2015 and up.
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
I believe the consensus was that 700...the 2014 model at least, doesn't have a tilt kill.
ah that would explain it. cause i had to cut mine off as well
KyleC
KyleC
102
155
Pittsburgh, PA
I can confirm, 14' 700 does not have a tilt cut-off. Engine ran until I turned the key.
91D9C0D4 F021 43FB A17D 49EBA6E82FB6
68,424
We have confirmed 1000 has an oil level sensor that will cut it off. Most prominent when on the tilted on the driver's side.
Assume Talon would be the same.
Unsure about the 500/700's.
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
Think the 500 and 700 are the same as the atv equivalents. Seen a couple videos but never watched them cause mine never cut off. But if its an oil sensor. I wonder if just running a hair high on oil would help the angle any.
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
I've drained the oil completely before and ran mine (Flushing out water). Where is this sensor??
They have a tilt/angle sensor... def not an oil level sensor because my 2021 1K5 runs with the drain plug out.
Good question. Unless yours is faulty. I wish i knew lol
kamikaze
kamikaze
74
160
Linden, NC
Says the guy named Kamikaze! LOL!!! 🛬
haha! Yes, things get wild around here! I recently sank my 2021 P1K5 (less than 20hrs/100miles on the clock) in some quicksand mix up to the headrest. We broke the 6K lb winch cable, 6 atv's tied together couldn't get it out and we ended up having to get it out with an excavator... Insurance deemed it a total loss and I bought it back. IF YOU DON'T HAVE INSURANCE GET IT!!
Crazy story, once the quick sand came up to the pedals it mashed the throttle and it was in gear... It stayed in the hole for a good 30-45 minutes almost at full throttle, which only made it sink faster. We couldn't get it out of gear and I didn't want to cut it off while the exhaust was under... It's snorkeled over the roof and it only cut off because the main 40A fuse blew for some reason. Water ended up coming in the exhaust and filled the engine. Got it running and I'm still in the process of flushing it out. It tends to pump more fluid out when you run it for a few seconds with the plug out. Been filling it with diesel and running it for a few, draining it and repeating the process. Almost have it back to 100%. The display no longer works so have to replace that but it's getting there.
Farmer
Farmer
2,975
17,169
Southern MO
Yeah... I'd say that qualifies your screen name pretty good! Got any pics of that chaos???
Reactions: Isaiah and Mudwing
