Tinker
Tinker
amc019
amc019
480
592
Little Rock, Ar
The bendable hose through the hood compartment and up through the cup holder looks like the way to go. Interested to see how it turns out from there.
F
Fullthrottle
164
84
Passengers gonna be choked taking away their bevy holder.
Reactions: MNnice
Up2It
Up2It
Calgary Alberta
Messed around a little last night with how to make a battery holder downer, I have some of these connectors that are used to hold body panels on pretty much just insert and a half twist an it locks the connector. I just cut a slight hole for it to slide into the back side of the plastic a couple O rivets. The metal brace was just pieces of metal left over from a different project I will prob bend it all on piece instead of the welds later but overall for a prototype works well so far.
View attachment 9890 View attachment 9891 View attachment 9892 View attachment 9893
Nice use of Dzus fasteners!
Hometeam
Hometeam
976
4,009
Normal, IL
Great idea on the battery fastener! I have the same battery and was just looking at it last night trying to decide how to secure it.
Looks real good!
Reactions: pct
Kilo427
Kilo427
1,543
6,440
Got a parking brake done tonight temporarily but it will work. Explanation when I'm not at shop to come.
Kilo427
Kilo427
1,543
6,440
Less than 1 amp it's not a long term solution you could do the same with a manual lock but you would need to run the lines up to dash, which I may do. But then again I don't really trailer the rig many places. I am going to use this switch with a lock for the time being and see how it works.
CONTURA V, LOCKING ROCKER WITH SINGLE DAYLIGHT BRIGHT RED LED, LOWER INDEPENDENT LED ONLY
And no I don't plan on keeping those crappy compression fittings I did order the correct lines just hard to find a 1/8 npt to 10mm brake line adapter around here so it's just kinda of a test.
Reactions: CashMoney
CashMoney
CashMoney
329
211
Reno, NV
www.SRTNV.com
I'm lucky, summit racing is a block away from my shop. I'm thinking about doing an electric line lock too, I just know though I'd forget and leave it on. Glad to see you're trying it.
322,690
Up this week in the build list before takeover
A arms (if they come in)
Lift (if A arms don't come in)
Radio
Finish switch panel
Finish wiring
Change IGR main drive gear
Finish soft top
Door bags
Mirror
Uninstall bellows and run vent hoses
Cab light
Oh and build some wheel well armor so my twig and berries are safe
So not much.... if I don't sleep lol
So not just igr! ... it's the final countdown.
E
elkguide
3,377
7,964
Vermont
Radio
Finish switch panel
Finish wiring
Finish soft top
Door bags
Mirror
Cab light
Don't forget that we "NEED" pictures as you go!!!!!
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Haven't been to sleep yet but I finally got wiring all tucked away, radio finished, switch panel done. Those mini 4200 Phoenix make wiring fairly easy some of the switches are hooked to a relay in that sealed fuse box depending on voltage. Got a red dome light wired up as well.
Also finished running all vent hoses and took off the bellows so as not to blow a seal. Although I didn't take the bellows off the fan not sure that really matter on that line.
Next up: tear it completely apart remove heat and Sound shielding that I Fabricated and replace IGR gears. I just hope A arms come in before go time I really want these damn tires to stop mocking me
View attachment 40561 View attachment 40562 View attachment 40563 View attachment 40564 View attachment 40566
Looks good man!
322,690
Kicking ass. Funny about those wheels ya no s*** I'd want them on too they look good!
Reactions: pct and sharp
I looked at the Full size Feniex 4200 but I already had all the switches from my 700. I REALLY liked the 4200 minis but since I already had 200$ in switches It was hard to justify them.
E
elkguide
3,377
7,964
Vermont
Those switches really do make it!!!!
E
elkguide
3,377
7,964
Vermont
Creativity can be fun...... or maybe funny!
Reactions: CumminsPusher
